Stop PWM signal
Hi, may somebody explain me why I'm not able to stop a PWM signal once it's started? Here's the code:
  pinMode(11,OUTPUT);
  digitalWrite(11,LOW);
  while(!Serial.available());
  switch(Serial.read()){
  case 'i':
    analogWrite(11,127);
  case 'o':
I'm only able to stop it using
analogWrite(11,0);
even if inside the reference you'll find
After a call to analogWrite(), the pin will generate a steady square wave of the specified duty cycle until the next call to analogWrite() (or a call to digitalRead() or digitalWrite() on the same pin)
Not sure, but your switch() statement seems to be incomplete. You should add default: break;
This is only a minimal code to explain my problem, but it's not inside a switch statement in my program and although it doesn't work..
The default isn't required.
This works perfectly for me. What board and version of the IDE are you using?
const byte PWMpin = 11;
  case 'i':
    analogWrite(PWMpin, 127);
  case 'o':
    digitalWrite(PWMpin, LOW);
Arduino DUE with 1.5.2 IDE
Hello goan,
analogWrite puts PWMpin into a PWM mode. digitalWrite will not work on that mode, thus, before use it you must set up PWMpin as output. I am not sure if the Arduino team is working on this. Regards!
case 'i':
  case 'o':
    pinMode(PWMpin,OUTPUT);
Hi Palliser, thank for your suggestion. Your workaround let me stop PWM, but then I'm not able to start it again.. This is an unpleasant behaviour, the only way I found to start and stop it, is to change the dutycycle. If someone has other idea, please let me know. Is this problem due to arduinoDUE? Does anybody had in the past the need to start and stop PWM signal? I can't believe I'm the first... :-)
I'm only able to stop it using Code: analogWrite(11,0);
I confess to being puzzled as to why this is a problem - it seems an obvious approach to me
Don't you think that it's a problem not being able to change a pin mode once you use analogWrite to a pin? So, the only way to change that pin functionality is to rewrite the firmware? It seems quite ridiculous..
Possibly, but since there's an effective workaround (analogWrite (pin, 0) / analogWrite (pin, 255) ), I can't get too agitated about it.
Ok, thanks anyway... I would only know if it was a limit of mine in making it work, beacause inside the reference it's written you can..
