Stop reconnect attempt
Hi!
I have an iot project where I am sending data from a board to both the iot cloud and my own webserver. I want to send this data mainly through a local wifi, however if the power cuts out, I want my data transfer to happen through a 4G cellular connection. I should mention that the cellular connection is also established with wifi, through a portable router with a sim card inserted.
I have my arduino iot 33 board configured to detect the loss of an internet connection, and when this happens, it can connect without a problem to the cellular network. The preferred connection for the iot cloud is the wifi and so it keeps on trying to reconnect, therefore disconnecting my board from the cellular connection.
Is there a way to stop the cloud from trying to reconnect every 500 ms?
Alternatively, the best option would be if I could add the cellular connection's SSID and PASS as a second connection option for the cloud, however if I could just stop the cloud from attempting to reconnect, that would save my issue too.
My code:
  Sketch generated by the Arduino IoT Cloud Thing "Untitled"
  https://create.arduino.cc/cloud/things/cd1e9668-0bdf-4950-af6a-6a6c2c1575cb
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  String conn_type;
  float bat_voltage;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include <SPI.h>
#include <WiFiNINA.h>
#include "thingProperties.h"
#define bat_pin A6
int status = WL_IDLE_STATUS;
bool setup_connect=false;
unsigned long time_elapsed;
unsigned long time_setup_wifi=0;
float bat_volt;
float R1 = 7500.0;
float R2 = 750.0;
float ref_volt = 2.048;
float adc_value;
float adc_volt;
  // Initialize serial and wait for port to open:
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(3000);
  analogReference(AR_EXTERNAL);
  analogReadResolution(12);
  pinMode(LED_BUILTIN, OUTPUT);
  conn_type="nc";
  status= WL_IDLE_STATUS;
  int wifisetup_counter = 0;
  while(status!=WL_CONNECTED)
     if(wifisetup_counter>3) break;
     status = WiFi.begin(SSID1,PASS1);
     if(status==WL_CONNECTED){
       Serial.println("Connected with wifi!");
       setup_connect=true;
       conn_type="W";
     else delay(10000);
     wifisetup_counter++;
  int cellularsetup_counter = 0;
     if(cellularsetup_counter>3) break;
     status = WiFi.begin(SSID2,PASS2);
       Serial.println("Connected with cellular!");
       conn_type="C";
       setup_connect=true;
     else delay(10000);
     cellularsetup_counter++;
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection, false);
     The following function allows you to obtain more information
     related to the state of network and IoT Cloud connection and errors
     the higher number the more granular information you’ll get.
     The default is 0 (only errors).
     Maximum is 4
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  digitalWrite(LED_BUILTIN, HIGH);  // turn the LED on (HIGH is the voltage level)
  delay(1000);                      // wait for a second
  digitalWrite(LED_BUILTIN, LOW);   // turn the LED off by making the voltage LOW
  Serial.println(conn_type);
  Serial.println(WiFi.status());
  TestWiFiConnection();
  ArduinoCloud.update();
  // Your code here
  adc_value=analogRead(bat_pin);
  adc_volt=(analogRead(bat_pin)*ref_volt)/4096.0;
  bat_volt = ((analogRead(bat_pin)*ref_volt)/4096.0)/(R2/(R1+R2));
  Serial.println(adc_value);
  Serial.println(adc_volt);
  Serial.println(bat_volt);
  bat_voltage = bat_volt;
  Serial.println(bat_voltage);
void TestWiFiConnection()
//test if always connected
  Serial.println("Testing conn...");
  Serial.println(WiFi.SSID());
  Serial.println("Wifi status:");
  Serial.print(WiFi.status());
  int StatusWiFi=WiFi.status();
  if(strcmp(WiFi.SSID(),SSID2)==0 &&(StatusWiFi!=WL_CONNECTION_LOST && StatusWiFi!=WL_DISCONNECTED)){
    if(ScanSSIDs()==1) {
      Serial.println("Switching to wifi...");
      WiFiConnect();
    StatusWiFi=WL_CONNECTED;
  if(StatusWiFi==WL_CONNECTION_LOST || StatusWiFi==WL_DISCONNECTED ||
    setup_connect == false) //if no connection
  Serial.println("Connection lost...");
  conn_type="nc";
  //ArduinoCloud.end();
  if(ScanSSIDs()==1) WiFiConnect();
  if(ScanSSIDs()==2) CellularConnect();
void WiFiConnect()
//connect to my SSID
 Serial.println("Connectin to wifi");
  int wifi_timeout=0;
   if(wifi_timeout>6) break;
     conn_type="W";
     if (ArduinoCloud.connected()==false) {
       ArduinoCloud.begin(ArduinoIoTPreferredConnection, false); <---The cloud cannot handle 2 connection attempts at the same time
   else {
     delay(10000);
     wifi_timeout++;
void CellularConnect()
  Serial.println("Connecting to cellular");
  int cellular_timeout=0;
   if(cellular_timeout>6) break;
     conn_type="C";
       ArduinoCloud.begin(ArduinoIoTSecondConnection, false); <---The cloud cannot handle 2 connection attempts at the same time
   else {
     delay(10000);
     cellular_timeout++;
int ScanSSIDs()
//scan SSIDs, and if my SSID is present return 1
Serial.println("Scanning...");
 int score=0;
 int numSsid = WiFi.scanNetworks();
 if(numSsid==-1) return(0); //error
 for(int thisNet=0;thisNet<numSsid;thisNet++){
    Serial.println(WiFi.SSID(thisNet));
    if(strcmp(WiFi.SSID(thisNet),SSID1)==0) score=1;
    else if(strcmp(WiFi.SSID(thisNet),SSID2)==0){
      score=2;
 Serial.println("Score:");
 Serial.println(score);
 return(score);
Code in thingProperties.h:
// Code generated by Arduino IoT Cloud, DO NOT EDIT.
#include <ArduinoIoTCloud.h>
#include <Arduino_ConnectionHandler.h>
const char SSID1[]     = SECRET_SSID1;    // Network SSID (name)
const char PASS1[]     = SECRET_OPTIONAL_PASS1;    // Network password (use for WPA, or use as key for WEP)
const char SSID2[]     = SECRET_SSID2;    // Network SSID (name)
const char PASS2[]     = SECRET_OPTIONAL_PASS2;    // Network password (use for WPA, or use as key for WEP)
String conn_type;
float bat_voltage;
void initProperties(){
  ArduinoCloud.addProperty(conn_type, READ, ON_CHANGE, NULL);
  ArduinoCloud.addProperty(bat_voltage, READ, ON_CHANGE, NULL);
WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID1, PASS1);
WiFiConnectionHandler ArduinoIoTSecondConnection(SSID2, PASS2);
Thank you very much for everybody's response in advance and have nice day!
Hi @Istvan99. You can configure the automatic reconnection behavior via the optional 3rd parameter of the WiFiConnectionHandler constructor (keep_alive). Simply set it to false if you don't want it to reconnect:
Hi @ptillisch! Thank you for your response!
The problem is that the bool variable keep_alive is declared as a constant, so I cannot change the value after the wificonnectionhandler was created. I want the connection to the cloud to be kept alive, until there is a disconnect wifi status.
I was considering editing the Arduino_ConnectionHandler.h library by adding a public function that would change the NetworkConnectionState to NetworkConnectionState::CLOSED , so that the ConnectionHandler::check() function breaks, but I don't wish to edit the library if there is a workaround. :slight_smile:
Hello there,
did you find some solution for this?
Pol.
