Stop send measurements arduino esp8266
I have made sketch with arduino uno and esp8266 in which i send measures of HC-SR04 to a website. Firstly my code was:
#include <SoftwareSerial.h>
SoftwareSerial espSerial =  SoftwareSerial(2,3);
boolean DEBUG=true;
int echoPin = 12;
int trigPin = 13;
long duration, distance;
int alarm;
String alarms;
String data;
String server = "www.example.com"; // Send data to this site
String uri = "/add2.php";
int error = 0;
int cancel = 0;
void showResponse(int waitTime){
    long t=millis();
    char c;
    while (t+waitTime>millis()){
      if (espSerial.available()){
        c=espSerial.read();
        if (DEBUG) Serial.print(c);
boolean websiteWrite(long value1, int value2){
  if (value2 == 0){
    alarms = "OFF";
  }else{
    alarms = "ON";
  data = "distance=" + String(value1) + "&alarm=" + alarms;
  espSerial.println("AT+CIPSTART=\"TCP\",\"" + server + "\",80");//start a TCP connection.
  if( espSerial.find("OK")) {
  Serial.println("TCP connection ready"); cancel = 0;
  else{
    cancel = cancel + 1;  Serial.println("cancel="); Serial.println(cancel);
  String postRequest =
  "POST " + uri + " HTTP/1.0\r\n" +
  "Host: " + server + "\r\n" +
  "Accept: *" + "/" + "*\r\n" +
  "Content-Length: " + data.length() + "\r\n" +
  "Content-Type: application/x-www-form-urlencoded\r\n" +
  "\r\n" + data;
  String sendCmd = "AT+CIPSEND=";//determine the number of caracters to be sent.
  espSerial.print(sendCmd);
  espSerial.println(postRequest.length() );
  if(espSerial.find(">")) { Serial.println("Sending.."); espSerial.print(postRequest);
  if( espSerial.find("SEND OK")) { Serial.println("Packet sent");
  while (espSerial.available()) {
  String tmpResp = espSerial.readString();
  Serial.println(tmpResp);
  // close the connection
  espSerial.println("AT+CIPCLOSE");
    error = 0;
  }else{
    error = error + 1;
    Serial.println("error=");
    Serial.println(error);
  if(cancel >=15 || error >= 15){software_Reset() ;}
  delay(150000);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  DEBUG=true;
  espSerial.begin(9600);
  //espSerial.println("AT+RST");
  //showResponse(1000);
  //espSerial.println("AT+UART_DEF=9600,8,1,0,0");
  espSerial.println("AT+CWMODE=1");
  showResponse(1000);
  espSerial.println("AT+CWJAP=\""+ssid+"\",\""+password+"\"");
  showResponse(5000);
  if (DEBUG)  Serial.println("Setup completed");
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = duration/58.2;
  if (distance<=8){
    alarm=1;
  }else{
    alarm=0;
      if (isnan(distance)) {
        if (DEBUG) Serial.println("Failed of calculation the distance");
      else {
          if (DEBUG)  Serial.println("Distance="+String(distance)+" cm");
           websiteWrite(distance,alarm);                                      // Write values to website
  //Needs 60 sec delay between updates
  delay(60000);
void software_Reset() // Restarts program from beginning but does not reset the peripherals and registers
asm volatile ("  jmp 0");
But after a few days stop send measurements to website. I followed someone’s comments here in the forum and convert Strings to char arrays so there are no strings they cause heap fragmentation. My code is:
void(* software_Reset) (void) = 0;
boolean DEBUG=true;
int echoPin = 12;
int trigPin = 13;
int alarm;
const int distancesSize = 20;
char distances[distancesSize+1];
char* alarms;
const int dataSize = 200;
char data[dataSize+1];
const char* server = "www.example.com"; // Send data to this site
const char* uri = "/add5.php";
int cancel = 0;
int error = 0;
    long t=millis();
    char c;
        c=espSerial.read();
  if (value1 > 500){
   strncpy(distances, distancesSize, ">500");
  }else{
    snprintf(distances,
      distancesSize,
      ("%d"),
      value1);
 if (value2 == 0){
    alarms = "OFF";
  }else{
    alarms = "ON";
  snprintf(data,
      dataSize,
      ("distance=%s &alarm=%s"),
      distances,
      alarms);
  espSerial.println("AT+CIPSTART=\"TCP\",\"" "www.example.com" "\",80");//start a TCP connection.
  Serial.println("TCP connection ready"); error = 0;
  else{
    error = error + 1;  Serial.println("error="); Serial.println(error);
  const int postRequestSize = 500;
  char postRequest[postRequestSize+1];
   snprintf(postRequest,
      postRequestSize,
      "POST %s HTTP/1.0\r\nHost: %s\r\nAccept: */*\r\nContent-Length: %d\r\nContent-Type: application/x-www-form-urlencoded\r\n\r\n%s",
      uri,
      server,
      strlen(data),
      data);
  char* sendCmd = "AT+CIPSEND=";//determine the number of caracters to be sent.
  espSerial.println(strlen(postRequest));
  Serial.println(espSerial.readString());
    cancel = 0;
  }else{
  if(error >=15 || cancel >= 15){software_Reset() ;}
  delay(150000);
  DEBUG=true;
  showResponse(1000);
  espSerial.println("AT+CWJAP=\"ssid\",\"password\"");
  showResponse(5000);
  if (distance<=8){
    alarm=1;
  }else{
    alarm=0;
      else {
  delay(60000);
Τhe problem remains and don’t send measurements to website after few days. Do I have a bug in the code? What can I do to solve it?
Your code STILL uses Strings.
Stop using that function.
Turn up the level of compiler warnings in preferences; it reveals a number of problems.
If i stop using the function readString(),then there is a problem sending data, when it sends and when not. How can I stop using this function and run the code properly? Can I convert this function to read()?
Then the problem is with whatever code you wrote to replace readString(). Post your attempt.
I presume you mean write, not run. That's simple. Use a text editor and your brain.
Of course you can. After all, readString() calls read().
My code is the previous without the lines:
The previous what?
What did you replace those line with?
  if (value1 > 500){
  }else{
    snprintf(distances,
      distancesSize,
      ("%d"),
      value1);
%d is not the correct format specifier for a long.
I deleted these lines of code. My new code is:
These lines?
Yes these lines I deleted and it shows me the problem. My code is
boolean DEBUG=true;
int echoPin = 12;
int trigPin = 13;
int alarm;
char* alarms;
int cancel = 0;
int error = 0;
    long t=millis();
    char c;
        c=espSerial.read();
  if (value1 > 500){
  }else{
    snprintf(distances,
      distancesSize,
      ("%d"),
      value1);
 if (value2 == 0){
    alarms = "OFF";
  }else{
    alarms = "ON";
  snprintf(data,
      dataSize,
      distances,
      alarms);
  else{
      postRequestSize,
      uri,
      server,
      strlen(data),
      data);
    cancel = 0;
  }else{
  delay(150000);
  DEBUG=true;
  showResponse(1000);
  showResponse(5000);
  if (distance<=8){
    alarm=1;
  }else{
    alarm=0;
      else {
  delay(60000);
You need to explain this. What shows you a problem? What is the problem that it, whatever it is, shows you?
You were supposed to replace the line in the body with code that uses read() in a loop, to read all the data.
PaulS: You were supposed to replace the line in the body with code that uses read() in a loop, to read all the data.
Tell him Paul ! oh i you use just a single loop, make sure you get the whole response, 1200 us per byte.
