Stop the arduino code for 24 hours
How can I putthe arduino,for exemple,lihting a LED for 10s and remains off 23h59m50s.
I did try with "delay()" but didn't work with bi numbers.
ruineves:
.. bi numbers.
What?
I look forward to seeing the code you tried.
How accurate does the timing need to be ?
big numbers
You should definately not use delay(). You should use timing with millis() or you should use a library which does that for you. If your problem is "big numbers" then you are probably in need of different data types (eg. long instead of int).
for exemple
digitalWrite(13;HIGH);
delay(10000);
digitalWrite(13;LOW);
delay(86390);
didn't work, only did stop 20seconds even when using long parameters
delay() takes milliseconds as argument, 24 hours is 86400000 milliseconds.
Try:
digitalWrite(ledPin,HIGH);
delay(10000);
digitalWrite(ledPin,LOW);
delay(86390000UL);
// or 1000UL * 60 * 60 * 24 - 10000;
Literal numbers are assumed by the compiler to be ints (signed 16 bit integers that can hold values from -32768 to 32767) adding "UL" forces an Unsigned Long which can hold a tad over 4 billion (4294967295).
Better: :slight_smile:
const byte ledPin = LED_BUILTIN;
  //Serial.begin(9600);
  pinMode(ledPin,OUTPUT);
  static unsigned long timer = 0;
  unsigned long tEnd = 86400000; // 24 hrs
  int blinkTime = 10000; // 10 seconds
  digitalWrite(ledPin,millis() - timer < blinkTime);
  if(millis() - timer > tEnd)
    timer += tEnd;
ruineves:
for exemple
delay(10000);
delay(86390);
// Define some time constants in milliseconds
const unsigned long SECONDS = 1000UL;
const unsigned long MINUTES = 60 * SECONDS;
const unsigned long HOURS = 60 * MINUTES;
const unsigned long DAYS = 24 * HOURS;
// Note: unsigned long is good for about 47 days in milliseconds
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);
  delay(10 * SECONDS);
  digitalWrite(13, LOW);
  delay(1 * DAYS - 10 * SECONDS);
I have a program that turns my spa on for two hours in every twenty-four hours. It uses millis() and not delay(...), much as johnwasser has shown but using millis(). It drifts slightly but the drift is acceptable. There is a calibration offset for the drift that works for a specific Uno in a specific environment to reduce the drift.
Because of the steps needed to turn the spa on and off, I use a Finite State Machine and a slightly more complex program, but the principles are similar.
Danois90:
The advice not to use delay() is common here but is somewhat of a knee jerk reaction. If the program is doing nothing else then using delay() is perfectly acceptable.
The problem comes when we have not been told the whole story and/or when the requirement changes. For instance, in this case, if a requirement was added later to respond to an input during the delay() period.
UKHeliBob:
Agreed, but a delay of nearly 24 hours is silly - OP should (if possible) put the arduino into low power mode instead :slight_smile:
