Stop Watch (solved)
So using various sources I’ve been making a stop watch device.
One issue I’m having is that I’m trying to make my colon more centred and everytime I try to adjust
Code is the one with colon centered but ruins all the other numbers
// include the library
#include <Wire.h>
// initialize the interface pins
LiquidCrystal_I2C lcd(0x3f,16,2); // 0x20 is adresss for LCC 16x2
// the 8 arrays that form each segment of the custom numbers
byte bar1[8] =
        B11100,
        B11110,
        B11110,
        B11110,
        B11110,
        B11110,
        B11110,
        B11100
byte bar2[8] =
        B00111,
        B01111,
        B01111,
        B01111,
        B01111,
        B01111,
        B01111,
        B00111
byte bar3[8] =
        B11111,
        B11111,
        B00000,
        B00000,
        B00000,
        B00000,
        B11111,
        B11111
byte bar4[8] =
        B11110,
        B11100,
        B00000,
        B00000,
        B00000,
        B00000,
        B11000,
        B11100
byte bar5[8] =
        B01111,
        B00111,
        B00000,
        B00000,
        B00000,
        B00000,
        B00011,
        B00111
byte bar6[8] =
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B11111,
        B11111
byte bar7[8] =
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B00111,
        B01111
byte bar8[8] =
        B11111,
        B11111,
        B11111,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000
byte bar9[8] =
        B00000,
        B00000,
        B11111,
        B11111,
        B11111,
        B11111,
        B00000,
        B00000
// variables will change:
int value = 0;
//Timing
const byte interruptPin1 = 2;
const byte interruptPin2 = 3;
int state = LOW;
int led = 10;
//Backlight Brightness
int backlightPin = 6;
int brightness = 50;
  lcd.begin();
  // assignes each segment a write number
  lcd.createChar(1,bar1);
  lcd.createChar(2,bar2);
  lcd.createChar(3,bar3);
  lcd.createChar(4,bar4);
  lcd.createChar(5,bar5);
  lcd.createChar(6,bar6);
  lcd.createChar(7,bar7);
  lcd.createChar(8,bar8);
  lcd.createChar(9,bar9);
 lcd.backlight(); //backlight is now ON
 // initialize the pushbutton pin as an input:
  pinMode(interruptPin1, INPUT_PULLUP);
  pinMode(interruptPin2, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(interruptPin1), resetvalue, CHANGE);
  attachInterrupt(digitalPinToInterrupt(interruptPin2), startstop, CHANGE);
  pinMode(led, OUTPUT);
  pinMode(backlightPin, OUTPUT);
  state = LOW;
  digitalWrite(led, LOW);
  analogWrite(backlightPin, brightness);
void customcol(int col)
{ // uses segments to build the colon
  lcd.setCursor(col, 0);
  lcd.write(9);
  lcd.setCursor(col,1);
  lcd.write(9);
void custom0(int col)
{ // uses segments to build the number 0
  lcd.write(2);
  lcd.write(8);
  lcd.write(1);
  lcd.setCursor(col, 1);
  lcd.write(2);
  lcd.write(6);
  lcd.write(1);
void custom1(int col)
  lcd.setCursor(col,0);
  lcd.write(32);
  lcd.write(32);
  lcd.write(1);
  lcd.write(32);
  lcd.write(32);
  lcd.write(1);
void custom2(int col)
  lcd.write(5);
  lcd.write(3);
  lcd.write(1);
  lcd.write(2);
  lcd.write(6);
  lcd.write(6);
void custom3(int col)
  lcd.write(5);
  lcd.write(3);
  lcd.write(1);
  lcd.write(7);
  lcd.write(6);
  lcd.write(1);
void custom4(int col)
  lcd.write(2);
  lcd.write(6);
  lcd.write(1);
  lcd.write(32);
  lcd.write(32);
  lcd.write(1);
void custom5(int col)
  lcd.write(2);
  lcd.write(3);
  lcd.write(4);
  lcd.write(7);
  lcd.write(6);
  lcd.write(1);
void custom6(int col)
  lcd.write(2);
  lcd.write(3);
  lcd.write(4);
  lcd.write(2);
  lcd.write(6);
  lcd.write(1);
void custom7(int col)
  lcd.write(2);
  lcd.write(8);
  lcd.write(1);
  lcd.write(32);
  lcd.write(32);
  lcd.write(1);
void custom8(int col)
  lcd.write(2);
  lcd.write(3);
  lcd.write(1);
  lcd.write(2);
  lcd.write(6);
  lcd.write(1);
void custom9(int col)
  lcd.write(2);
  lcd.write(3);
  lcd.write(1);
  lcd.write(7);
  lcd.write(6);
  lcd.write(1);
void printNumber(int value, int col) {
  if (value == 0) {
    custom0(col);
  } if (value == 1) {
    custom1(col);
  } if (value == 2) {
    custom2(col);
  } if (value == 3) {
    custom3(col);
  } if (value == 4) {
    custom4(col);
  } if (value == 5) {
    custom5(col);
  } if (value == 6) {
    custom6(col);
  } if (value == 7) {
    custom7(col);
  } if (value == 8) {
    custom8(col);
  } if (value == 9) {
    custom9(col);
void printRPM(int rpm) {
  int n, m , c, d, u, number;
  number = rpm;
 if (number > 5999) {
    n = (number - (number % 6000)) / 6000;
    number = number % 6000;
    n = 0;
  if (number > 599) {
    m = (number - (number % 600)) / 600;
    number = number % 600;
    m = 0;
  if (number > 59) {
    c = (number - (number % 60)) / 60;
    number = number % 60;
    c = 0;
  if (number > 9) {
    d = (number - (number % 10)) / 10;
    number = number % 10;
    d = 0;
  u = number;
  lcd.setCursor(0, 0);
  //printNumber(n, 0);
  printNumber(m, 3);
  printNumber(c, 6);
  customcol (9);
  printNumber(d, 10);
  printNumber(u, 13);
void startstop(){
 static unsigned long last_interrupt_time = 0;
 unsigned long interrupt_time = millis();
 // If interrupts come faster than 200ms, assume it's a bounce and ignore
 if (interrupt_time - last_interrupt_time > 300)
   state = !state;
   digitalWrite(led, !digitalRead(led));
 last_interrupt_time = interrupt_time;
void valueup()
  delay (1000);
  value=value +1;
void resetvalue(){
   value = 0;
void loop(){
printRPM(value);
if (state ==HIGH){
  valueup();
Original Code with working colon (but not centred colon)
#include <Wire.h>
byte bar1[8] =
        B11100,
        B11110,
        B11110,
        B11110,
        B11110,
        B11110,
        B11110,
        B11100
byte bar2[8] =
        B00111,
        B01111,
        B01111,
        B01111,
        B01111,
        B01111,
        B01111,
        B00111
byte bar3[8] =
        B11111,
        B11111,
        B00000,
        B00000,
        B00000,
        B00000,
        B11111,
        B11111
byte bar4[8] =
        B11110,
        B11100,
        B00000,
        B00000,
        B00000,
        B00000,
        B11000,
        B11100
byte bar5[8] =
        B01111,
        B00111,
        B00000,
        B00000,
        B00000,
        B00000,
        B00011,
        B00111
byte bar6[8] =
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B11111,
        B11111
byte bar7[8] =
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B00111,
        B01111
byte bar8[8] =
        B11111,
        B11111,
        B11111,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000
byte bar9[8] =
        B00000,
        B00000,
        B11111,
        B11111,
        B11111,
        B11111,
        B00000,
        B00000
int value = 0;
//Timing
int state = LOW;
int led = 10;
  lcd.begin();
  state = LOW;
  lcd.write(9);
  lcd.write(9);
  lcd.write(2);
  lcd.write(8);
  lcd.write(1);
  lcd.write(2);
  lcd.write(6);
  lcd.write(1);
  lcd.write(32);
  lcd.write(32);
  lcd.write(1);
  lcd.write(32);
  lcd.write(32);
  lcd.write(1);
  lcd.write(5);
  lcd.write(3);
  lcd.write(1);
  lcd.write(2);
  lcd.write(6);
  lcd.write(6);
  lcd.write(5);
  lcd.write(3);
  lcd.write(1);
  lcd.write(7);
  lcd.write(6);
  lcd.write(1);
  lcd.write(2);
  lcd.write(6);
  lcd.write(1);
  lcd.write(32);
  lcd.write(32);
  lcd.write(1);
  lcd.write(2);
  lcd.write(3);
  lcd.write(4);
  lcd.write(7);
  lcd.write(6);
  lcd.write(1);
  lcd.write(2);
  lcd.write(3);
  lcd.write(4);
  lcd.write(2);
  lcd.write(6);
  lcd.write(1);
  lcd.write(2);
  lcd.write(8);
  lcd.write(1);
  lcd.write(32);
  lcd.write(32);
  lcd.write(1);
  lcd.write(2);
  lcd.write(3);
  lcd.write(1);
  lcd.write(2);
  lcd.write(6);
  lcd.write(1);
  lcd.write(2);
  lcd.write(3);
  lcd.write(1);
  lcd.write(7);
  lcd.write(6);
  lcd.write(1);
  if (value == 0) {
    custom0(col);
  } if (value == 1) {
    custom1(col);
  } if (value == 2) {
    custom2(col);
  } if (value == 3) {
    custom3(col);
  } if (value == 4) {
    custom4(col);
  } if (value == 5) {
    custom5(col);
  } if (value == 6) {
    custom6(col);
  } if (value == 7) {
    custom7(col);
  } if (value == 8) {
    custom8(col);
  } if (value == 9) {
    custom9(col);
  number = rpm;
    n = 0;
  if (number > 599) {
    m = 0;
  if (number > 59) {
    c = 0;
  if (number > 9) {
    d = 0;
  u = number;
  printNumber(m, 3);
  printNumber(c, 6);
  customcol (9);
  printNumber(d, 10);
  printNumber(u, 13);
void startstop(){
   state = !state;
void valueup()
  delay (1000);
  value=value +1;
void resetvalue(){
   value = 0;
void loop(){
printRPM(value);
if (state ==HIGH){
  valueup();
mrteach:
You can only have eight custom characters.
You are trying to have nine custom characters. With this kind of display, that cannot work. What I believe will happen is that character #9 will replace character #1. (Is that what you see happening?)
If you really want your colon, you will need to find another solution.
Here is a datasheet: https://www.sparkfun.com/datasheets/LCD/HD44780.pdf
If you look at pages 17 and 18 of that datasheet, you will see two character sets. I do not know which, if either, your display uses: you will have to experiment to find out. Try displaying characters from whatever character set your display already has.
If all else fails, you could give up on your colon and just display an 'm' after the minutes and an 's' after the seconds.
void valueup()
  delay (1000);
  value=value +1;
There is another problem. A stopwatch based on delay() probably will not keep accurate time. (Try testing it against your wristwatch or a smartphone timer.)
When you define a custom character, the on-display representation changes (updates) to reflect the change - see LCD Module Pushwheel Animation – Arduino++ as an example that creates animation.
This open the possibility to just display the characters and then change the definition to update the display. hh:mm:ss uses exactly 7 characters (: is the same character).
Alternatively you can define characters to make the seven segment 'look'. This is explained here Double Height Digits on a Character LCD Module – Arduino++.
Hopefully this make sense.
odometer:
Really.. Ah didn't know there was a limit to custom characters. I believe that 9 was taking over 1. Makes perfect sense then. Thanks.
odometer:
void valueup()
  delay (1000);
  value=value +1;
Yup I did that a while a go and fixed the time (still used delays) and its very close to 99 minutes.
marco_c:
I think I understand. Thanks may try that in the future.
