STOPPING A SERVO
hello everybody,
I am making a servo project that moves according to the input from a PIR motion sensor. Currently, when the PIR sensor detects a motion, the servo will move.
But, when there is no motion detection, the server will still move.
Attached is my coding, I hope anyone can help me.
Thank you.
sketch_sep28b_TRY_SERVOR_SENSOR.ino (1.2 KB)
Your code tells the servo to move to 90 and then to 60 when the signal is HIGH.
It tells the servo to move to 0 when the signal is LOW.
If that is not what actually happens then you need to explain clearly what does happen.
Put in some code to print the value of val. Maybe it is not what you think it is
...R
So I have edited the code, as attached.
It is now, the servo will move to 60 when it is HIGH and move to 0 when it is LOW. does that make sense ?
But the problem now, my PIR is always detecting a motion, even when there is no movement. Meanwhile the servo, it is still moving despite being the PIR being HIGH or LOW.
I have also attached the screenshot of the value ‘val’, as attached.
Thank you.
sketch_sep28b_TRY_SERVOR_SENSOR.ino (1.16 KB)
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
this is the code
 #include <Servo.h>
int ledPin = 13;
int inputPin = 9;
int pirState = LOW;
int val = 0;
Servo myservo;
int pos = 0;
//long interval = 1000;
//unsigned long lastSpuit = 0;
  myservo.attach(8);
  pinMode(ledPin, OUTPUT);      // declare LED as output
  pinMode(inputPin, INPUT);     // declare sensor as input
  Serial.begin(9600);         // Start serial communication at 9600 bps
   val = digitalRead(inputPin);  // read input value
  if (val == HIGH) {
    digitalWrite(ledPin, HIGH);  // turn LED ON
    if (pirState == LOW) {
      // we have just turned on
      Serial.println("Motion detected!");
      // We only want to print on the output change, not state
      pirState = HIGH;
    myservo.write(90);
    myservo.write(pos);
  else {
     digitalWrite(ledPin, LOW); // turn LED OFF
      if (pirState == HIGH){
      // we have just turned of
    Serial.println("Motion ended!");
    pirState = LOW;
     myservo.write(pos);
attached is the picture
The code in Reply #4 does not print the value of the variable val. In fact the code is almost identical to the code in your Original Post.
Write a simple program that gets a value from the PIR sensor and just prints the value to the Serial Monitor. There is no point worrying about other parts of the program until you can read the sensor reliably.
Post a link to the datasheet for the PIR sensor.
Also post a diagram showing clearly how you have connected the sensor to your Arduino.
What, exactly, do you mean by
...R
Robin2:
Sage advice.
@OP your code looks in fact like adafruit's from here: does it work properly in its virgin state with your actual sensor?
kenwood120s:
Sage advice.
yes, the code works fine in its original state. the problem rises when I start adding the code for servo motor. the servo does not stop when the PIR is at LOW state. it keeps moving.
sarahisml:
Post the working “original state” program and the code that represents your best attempt to add the servo.
…R
The code looks OK so I suspect a hardware problem. nCommon servo mistakes are:
  1. Using the Arduino's +5V pin to power the servo (the servo can cause the Arduino to reset)
  2. Using an external power supply for the servo but forgetting to connect the negative side of that supply to the Arduino Ground.
Robin2:
…R
this is the code for the PIR alone that is working
 * PIR sensor tester
int ledPin = 13;                // choose the pin for the LED
int inputPin = 9;               // choose the input pin (for PIR sensor)
int pirState = LOW;             // we start, assuming no motion detected
int val = 0;                    // variable for reading the pin status
void loop(){
  if (val == HIGH) {            // check if the input is HIGH
      pirState = HIGH;
      pirState = LOW;
and this is the code that I have added commands for servo
 #include <Servo.h>
int ledPin = 13;
int inputPin = 9;
int pirState = LOW;
int val = 0;
Servo myservo;
int pos = 0;
  myservo.attach(8);
  if (val == HIGH) {
      pirState = HIGH;
    myservo.write(90);
    myservo.write(pos);
  else {
    pirState = LOW;
     myservo.write(pos);
johnwasser:
most of the pages online suggested to power up the servo using the Arduino's +5V pin. if that is a mistake, where should I connect it to ?
thank you.
sarahisml:
You're right: the examples like this one do indeed suggest that.
Here's how to use an independent power supply.
sarahisml:
Your two programs are very similar. However you have a large number of tiny (and irrelevant) differences like extra blank lines and braces on different lines, or in different places on the line which made it very difficult to compare the two codes side by side.
You still have no code in the programs to print the values from the variable val. If the problem is caused by the current draw from the servo preventing the other things working that would be very obvious if you were monitoring the value of the variable.
It is also wise to put a Serial.println() statement into setup() so you can see if the program is continually re-starting. that current draw by the servo can also cause that.
And, even though I asked twice, you have not yet described the errant servo movement in detail. If you had (or do) it might immediately point to the behaviour one would expect if the Arduino is resetting.
...R
