Stopping blinking light after 20 seconds and keeping it on
Basically my objective is to move four servos after 20 seconds and keeping the light on after said 20 seconds.
#include <Servo.h>
#define LED 13
 Servo myservo1;
 Servo myservo2;
 Servo myservo3;
 Servo myservo4;
int angle = 0;
int number = 20;
void setup(){
  pinMode(LED,OUTPUT);
  pinMode(2, OUTPUT);
  //mosfet, LED, & Servo//
  myservo1.attach(11);
  myservo2.attach(10);
  myservo3.attach(9);
  myservo4.attach(8);
  myservo1.write(0);
  delay(100);
  myservo2.write(0);
  delay(100);
  myservo3.write(0);
  delay(100);
  myservo4.write(0);
  delay(100);
  digitalWrite(2,LOW);//mosfet which isn't needed rn//
  delay(100);
void loop(){
  if(number >= 10)
  digitalWrite(LED,HIGH);
  delay(100);
  digitalWrite(LED,LOW);
  delay(100);
   number - 1;
    if(number = 0){
       myservo1.write(90);
       myservo2.write(90);
       myservo3.write(90);
       myservo4.write(90);
       delay(100);
      digitalWrite(2,HIGH);//mosfet which isn't needed rn//
      delay(100);
      delay(100);
number - 2;
OOPS
if(number = 10)
OOPS
if(number >= 10)
Did you need
BTW
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
Use the </> icon from the ‘reply menu’ to attach the copied sketch.
This was a mistake. "number - 2" is "number - 1" and I though I could subtract 1 from whatever the number is at the time. And for "if(number = 10)" its ment to be "if(number = 0)". I changed all of this. I thought that I could basically say that if the number equals 0 during count down, then actuate servo.
Please do not edit previous posts.
number - 1;
No, check your syntax
if(number = 0){
= is not the same as ==
Topic LOCKED as a duplicate of this one.
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
