Ok.
If my battery runs down to say 3.3v however, will it not shutdown using the RAW pin?
My Lipo has protection down to 3v.
Need it to run for as long as possible!
The spec on the Sparkfun website says 3.4v min on the RAW pin.
Will the RAW pin regulator waste my battery life?
Sorry... still learning
SarahW2000:
That is the minimum voltage needed to keep the board running at 3.3volt (the regulator's ~0.1volt dropout).
But the board will keep on working if V-in drops well below that. 2.7volt should still be ok.
Question is what else you have connected to the ProMini.
That might not be happy with less than 3.3volt.
Leo..
SarahW2000:
Err… but I am not running at 5v?
My leds are set up for 3.3v operation and the sensor is also 3.3v max
Your Original Post just mentions the Pro Mini.
The Leds won’t care what voltage you use as long as the appropriate current limiting resistor is in place. Unless you are deliberately running them flat out from 3.3v then I reckon the existing resistors will be fine at 4.2v or even 5v.
You need to post a link to the datasheet or the sensor so we can see exactly what the specs are. Many things that are nominally 3.3v can actually take 3.6v or more.
