Hello,
I am a college student who encountered Arduino for the first time this semester. I'm applying the code I've learned to present an assignment, but I'm having a problem.
I'm trying to make a code with arduion uno to stop the tcs34725 rgb sensor at specific rgb value(R:47~48,G:89~90,B:99~100). Therefore I tried to use if but the error doesn't go away. I want to know that is it possible to stop sensor, and if it's possible, please help me to know the exact code to realize it.
#include <Wire.h>
#include <Adafruit_TCS34725.h>
#define redpin 3
#define greenpin 5
#define bluepin 6
#define commonAnode true
byte gammatable [256];
Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_50MS,TCS34725_GAIN_4X);
if (tcs.begin()){
Serial.println("NO TCS34725 found ... check your connections");
while (1);
#if defined (ARDUINO_ARCH_ESP32)
ledAttachPin (redpin, 1);
ledSetup(1, 12000, 8);
ledAttachPin (greenpin, 2);
ledSetup(2, 12000, 8);
ledAttachPin ( bluepin, 3);
ledSetup(3, 12000, 8);
#else
pinMode(redpin, OUTPUT);
pinMode(greenpin, OUTPUT);
pinMode(bluepin, OUTPUT);
#endif
for (int i=0; i<256; i++) {
float x = i;
x /= 255;
x = pow(x, 2.5);
x *=255;
if (commonAnode) {
gammatable[i] = 255-x;
gammatable[i] = x;
void loop () {
float red,green,blue;
tcs.setInterrupt(false);
tcs.getRGB(&red, &green, &blue);
tcs.setInterrupt(true);
Serial.println("R:\t"); Serial.print(int(red));
Serial.println("\tG:\t"); Serial.print(int(green));
Serial.println("\tB:\t"); Serial.print(int(blue));
Serial.print("\n");
#if defined(ARDUINO_ARCH_ESP32)
ledWrite(1, gammatable[(int)red]);
ledWrite(2, gammatable[(int)green]);
ledWrite(3, gammatable[(int)blue]);
#else
analogWrite(redpin, gammatable[(int)red]);
analogWrite(greenpin, gammatable[(int)green]);
analogWrite(bluepin, gammatable[(int)blue]);
#endif
#if (47<red<48, 89<green<90, 99<blue<100) {
Error code is below
C:\Users\ASUS\Documents\Arduino\RGB\RGB.ino:59:43: error: token "{" is not valid in preprocessor expressions
C:\Users\ASUS\Documents\Arduino\RGB\RGB.ino:59:0: error: unterminated #if
Compilation error: token "{" is not valid in preprocessor expressions
