Stopping Servo motors
Greetings guys.
I’m trying to using a killswitch to stop servo motor from rotating when the switch turned HIGH.
this is the servo im using
How can I stop the servo from rotating at all when I press the killswitch?
#include <Servo.h>
Servo myservo;
int limitswitch = 2;
int led = 13;
  myservo.attach(9);
  pinMode(limitswitch, INPUT);
  pinMode ( led, OUTPUT);
  int switch1 = digitalRead(limitswitch);
  if (switch1 == LOW)
    myservo.write(90);
    delay(5000);
    myservo.write(180);
    delay(2000);
    myservo.write(0);
    digitalWrite(led, HIGH);
  if (switch1 == HIGH)
    myservo.detach();
    digitalWrite(led, LOW);
Connect the kill switch to the servo's power supply.
AWOL: Connect the kill switch to the servo's power supply.
is it possible to use command instead?
Yes, but you need to get rid of all those delay()s first.
holymarder: is it possible to use command instead?
Get rid of ALL the delay()s in your code.
Have a look at the demo Several Things at a Time which illustrates the use of millis() to manage timing and has a button and a servo working "at the same time"
...R
AWOL:
hmm kindly explain how does removing delay helps with it. if the killswitch is hit, the servo will just stop rotating doesn’t it?
holymarder: hmm kindly explain how does removing delay helps with it. if the killswitch is hit, the servo will just stop rotating doesn't it?
It won't be monitoring the kill switch in the middle of a delay(), so it won't know it's pressed until the delay() is done.
If the killswitch is wired to the servo power supply, yes, that's exactly what will happen.
What's more, it's reliable, and doesn't depend on any of your code.
AWOL: If the killswitch is wired to the servo power supply, yes, that's exactly what will happen.
well yes i understand that. just to clear my doubts, detach() is the same as placing the killswitch at the power supply yes?
but right now my code does not react to detach() because of the delay function?
No. With detach(), the servo remains powered.
Correct.
