Stopping, Starting
When I connect my usb and upload my sketch, it runs perfectly until my program finishes. But how do I make it run again without connecting the usb and uploading it again? Also Is there a way to stop the sketch while it is running?
What program would that be?
I mean the sketch. When the sketch finishes, how do i make it restart again without uploading using the usb? Also I'm running two motor using transistors and If my sketch is running, say, both motors are to rotate for 15 seconds and stop, but halfway through i realise i want it to stop the sketch to save the battery or something, how do i do that without taking the batteries out. The reset button doesn't do anything.
Two definite articles, but no appearance of the sketch. (that's an oblique hint for you to post code)
const int transistorPin = 9;    // connected to the base of the transistors
const int transistorPin1 = 10;  // connected to the base of the transistors
   // set  the transistor pins as outputs:
   pinMode(transistorPin, OUTPUT);
   pinMode(transistorPin1, OUTPUT);
   digitalWrite(transistorPin, HIGH); //turn on
   digitalWrite(transistorPin1, HIGH); //turn on
   delay(2700);
   digitalWrite(transistorPin1, LOW); //turn off
   delay(1950);
   delay(5750);
   delay(1950);
   delay(2000);
   digitalWrite(transistorPin, LOW); //turn off
   delay(1950);
   delay(5400);
   delay(1950);
   delay(1100);
   delay(1950);
   delay(3700);
Your code never “stops”.
As soon as it hits the end of “loop”, it gets called again, so every 30 seconds or so, the sketch repeats.
I can see no reason assume it stops and has to be uploaded again.
If you want to implement a pause, you’ll need to get rid of the delays and use the serial.available function to check for incoming serial messages.
I have seen your posts before so, I am guessing that this is your motor/tank project.
The last 2 lines of code shown below turn of the transistors for a very short moment that you will not likely be able to see because the loop repeats and you immediately turn the transistors back on.
Add a delay to the very end of the sketch, after the last two lines.
    delay(2700);
A simple way to implement your stop/start would be to put in a toggle switch. If it's on, the sketch runs. If it's off, the sketch stops. Check the switch status in between between the movements. (Or better yet, set up a for loop that goes through an array of movements and delay times, and check the switch as part of your for loop.)
transistorPin1 and transistorPin2 would make a lot more sense.
