Please see my Note at Replay #3
Hi there,
I'm just going to program a stopwatch.
A switch on pin 50 for starting and a push button on pin 51 for stop.
Each time you press the button on pin 50 should run its own time, which then stops at a pressure on the button at pin 51 again.
It is a continuous loop between start and stop.
It should be a time measurement for my slalom kart club.
This works currently, unfortunately, only in part.
I can press the button twice to pin 50 and 2 times the button on pin 51 and then have my 2 times.
But I press twice Pin 50, Pin 51, and then once again pin 50 to start a third time, he does nothing, not even when multiple pressing the button on pin 51
Thanks in advance
Markus1995
Below is the code.
#include <LiquidCrystal.h>
// select the pins used on the LCD panel
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// define some values used by the panel and buttons
int backLight = 10; // LCD Panel Backlight LED connected to digital pin 10
int lightLevel = 255; // Initialise light full on
int lcd_key = 0;
int adc_key_in = 0;
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
// read the buttons
int read_LCD_buttons()
adc_key_in = analogRead(0); // read the value from the sensor
// my [Mark Bramwell's] buttons when read are centered at these valies: 0, 144, 329, 504, 741
// we add approx 50 to those values and check to see if we are close
if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
if (adc_key_in < 50) return btnRIGHT;
if (adc_key_in < 195) return btnUP;
if (adc_key_in < 380) return btnDOWN;
if (adc_key_in < 555) return btnLEFT;
if (adc_key_in < 790) return btnSELECT;
return btnNONE; // when all others fail, return this...
#define ledPin 13 // LED connected to digital pin 13
#define buttonPin 50 // button on pin 50
#define buttonPin51 51 // button on pin 51
int value = LOW; // previous value of the LED
int buttonState; // variable to store button state
int buttonState51; // variable to store button state
int lastButtonState; // variable to store last button state
int lastButtonState51; // variable to store last button state
int blinking; // condition for blinking - timer is timing
int blinking51; // condition for blinking - timer is timing
long interval = 100; // blink interval - change to suit
long previousMillis = 0; // variable to store last time LED was updated
long startTime ; // start time for stop watch
long startTime51 ; // start time for stop watch51
long elapsedTime ; // elapsed time for stop watch
long elapsedTime51 ; // elapsed time for stop watch
int fractional; // variable used to store fractional part of time
int fractional51; // variable used to store fractional part of time
int start = 0;
int stop1 = 0;
unsigned long interval1 = 10000;
lcd.begin(16, 2); // start the LCD library
pinMode(buttonPin, INPUT); // not really necessary, pins default to INPUT anyway
pinMode(buttonPin51, INPUT); // not really necessary, pins default to INPUT anyway
digitalWrite(buttonPin, HIGH); // turn on pullup resistors. Wire button so that press shorts pin to ground.
digitalWrite(buttonPin51, HIGH); // turn on pullup resistors. Wire button so that press shorts pin to ground.
lcd.print("Bereit");
Zeit1();
Zeit2();
//ZEIT 1-----------------------------------------------------------------------------------------------------------------------------------------------
void Zeit1 () { // Zeit 1
// check for button press
buttonState = digitalRead(buttonPin); // read the button state and store
buttonState51 = digitalRead(buttonPin51);
if (buttonState == LOW && lastButtonState == HIGH && blinking == false){ // check for a high to low transition
// if true then found a new button press while clock is not running - start the clock
startTime = millis(); // store the start time
blinking = true; // turn on blinking while timing
delay(50); // short delay to debounce switch
start++;
lastButtonState = buttonState; // store buttonState in lastButtonState, to compare next time
else if (buttonState51 == LOW && lastButtonState51 == HIGH && blinking == true){ // check for a high to low transition
// if true then found a new button press while clock is running - stop the clock and report
elapsedTime = millis() - startTime; // store elapsed time
blinking = false; // turn off blinking, all done timing
stop1++;
// routine to report elapsed time
lcd.setCursor(0,0); // move cursor to beginning of line "0"
lcd.print("Zeit 1: ");
lcd.print( (int)(elapsedTime / 1000L)); // divide by 1000 to convert to seconds - then cast to an int to print
lcd.print("."); // print decimal point
// use modulo operator to get fractional part of time
fractional = (int)(elapsedTime % 1000L);
// pad in leading zeros - wouldn't it be nice if
// Arduino language had a flag for this? :)
if (fractional == 0)
lcd.print("000"); // add three zero's
else if (fractional < 10) // if fractional < 10 the 0 is ignored giving a wrong time, so add the zeros
lcd.print("00"); // add two zeros
else if (fractional < 100)
lcd.print("0"); // add one zero
lcd.print(fractional); // print fractional part of time
else{
//Zeit 2-----------------------------------------------------------------------------------------------------------------------------------------------
void Zeit2 () { // Zeit 2
buttonState51 = digitalRead(buttonPin51); // read the button state and store
if (buttonState == LOW && lastButtonState == HIGH && blinking51 == false && start % 2 == 1){ // check for a high to low transition
startTime51 = millis(); // store the start time
blinking51 = true; // turn on blinking while timing
delay(5); // short delay to debounce switch
lastButtonState51 = buttonState51; // store buttonState in lastButtonState, to compare next time
else if (buttonState51 == LOW && lastButtonState51 == HIGH && blinking51 == true && stop1 % 2 == 1){ // check for a high to low transition
elapsedTime51 = millis() - startTime51; // store elapsed time
blinking51 = false; // turn off blinking, all done timing
lcd.setCursor(0,2); // move cursor to beginning of line "2"
lcd.print("Zeit 2: ");
lcd.print( (int)(elapsedTime51 / 1000L)); // divide by 1000 to convert to seconds - then cast to an int to print
fractional51 = (int)(elapsedTime51 % 1000L);
if (fractional51 == 0)
else if (fractional51 < 10) // if fractional < 10 the 0 is ignored giving a wrong time, so add the zeros
else if (fractional51 < 100)
lcd.print(fractional51); // print fractional part of time
else{
