Stopwatch+RGB LED+IR Remote Error Code
The error code I'm receiving:
exit status 1
'add' was not declared in this scope
and if you can't open the program file:
#include <ir_Lego_PF_BitStreamEncoder.h>
#include <boarddefs.h>
#include <IRremoteInt.h>
#include <IRremote.h>
#include <TimerOne.h>
//the pins of 4-digit 7-segment display attach to pin2-13 respectively
int a = 2;
int b = 3;
int c = 4;
int d = 5;
int e = 6;
int f = 7;
int g = 8;
int d4 = 12;
int d3 = 11;
int d2 = 10;
int d1 = 9;
long n = 0;// n represents the value displayed on the LED display. For example, when n=0, 0000 is displayed. The maximum value is 9999.
int x = 100;
int del = 5;//Set del as 5; the value is the degree of fine tuning for the clock
int count = 0;//Set count=0. Here count is a count value that increases by 1 every 0.1 second, which means 1 second is counted when the value is 10
int RECV_PIN =22;
int bluePin = 26;
int greenPin = 28;
int redPin = 24;
IRrecv irrecv(RECV_PIN);
decode_results results;
Timer1.initialize(100000); // set a timer of length 100000 microseconds (or 0.1 sec - or 10Hz => the led will blink 5 times, 5 cycles of on-and-off, per second)
Timer1.attachInterrupt( add ); // attach the service routine here
//set all the pins of the LED display as output
pinMode(d1, OUTPUT);
pinMode(d2, OUTPUT);
pinMode(d3, OUTPUT);
pinMode(d4, OUTPUT);
pinMode(a, OUTPUT);
pinMode(b, OUTPUT);
pinMode(c, OUTPUT);
pinMode(d, OUTPUT);
pinMode(e, OUTPUT);
pinMode(f, OUTPUT);
pinMode(g, OUTPUT);
irrecv.enableIRIn();
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
if (irrecv.decode(&results)){
switch (results.value){
//PWR
case 0xFFA25D:
clearLEDs();//clear the 7-segment display screen
pickDigit(0);//Light up 7-segment display d1
pickNumber((n/1000));// get the value of thousand
delay(del);//delay 5ms
pickDigit(1);//Light up 7-segment display d2
pickNumber((n%1000)/100);// get the value of hundred
pickDigit(2);//Light up 7-segment display d3
pickNumber(n%100/10);//get the value of ten
pickDigit(3);//Light up 7-segment display d4
pickNumber(n%10);//Get the value of single digit
//set color red
analogWrite(redPin, 0xFF);
analogWrite(greenPin,0x00);
analogWrite(bluePin, 0x00);
case 0xFF22DD:
//set color light green
analogWrite(redPin, 0x00);
analogWrite(bluePin, 0xFF);
void pickDigit(int x) //light up a 7-segment display
//The 7-segment LED display is a common-cathode one. So also use digitalWrite to set d1 as high and the LED will go out
digitalWrite(d1, LOW);
digitalWrite(d2, LOW);
digitalWrite(d3, LOW);
digitalWrite(d4, LOW);
digitalWrite(d1, HIGH);
digitalWrite(d2, HIGH);
digitalWrite(d3, HIGH);
digitalWrite(d4, HIGH);
delay(del); //delay 5ms
break; //PLAY/PAUSE
switch(x){
case 0:
digitalWrite(d1, LOW); //LIGHT d1 up
case 1:
digitalWrite(d2, LOW); //LIGHT d2 up
case 2:
digitalWrite(d3, LOW); //LIGHT d3 up
default:
digitalWrite(d4, LOW); //LIGHT d4 up
//The function is to control 7-segment LED display to display numbers. Here x is the number to be displayed. It is an integer from 0 to 9
void pickNumber(int x)
switch(x)
default:
zero();
case 1:
one();
case 2:
two();
case 3:
three();
case 4:
four();
case 5:
five();
case 6:
six();
case 7:
seven();
case 8:
eight();
case 9:
nine();
void clearLEDs() //clear the 7-segment display screen
digitalWrite(a, LOW);
digitalWrite(b, LOW);
digitalWrite(c, LOW);
digitalWrite(d, LOW);
digitalWrite(e, LOW);
digitalWrite(f, LOW);
digitalWrite(g, LOW);
void zero() //the 7-segment led display 0
digitalWrite(a, HIGH);
digitalWrite(b, HIGH);
digitalWrite(c, HIGH);
digitalWrite(d, HIGH);
digitalWrite(e, HIGH);
digitalWrite(f, HIGH);
void one() //the 7-segment led display 1
void two() //the 7-segment led display 2
digitalWrite(g, HIGH);
void three() //the 7-segment led display 3
void four() //the 7-segment led display 4
void five() //the 7-segment led display 5
void six() //the 7-segment led display 6
void seven() //the 7-segment led display 7
void eight() //the 7-segment led display 8
void nine() //the 7-segment led display 9
void add()
// Toggle LED
count ++;
if(count == 10)
count = 0;
n ++;
if(n == 10000)
n = 0;
TRIAL_1.ino (6.82 KB)
(deleted)
So what would be the best course of action to get the stopwatch to turn on/play when I press a certain button and then stop counting when another button is pressed and at the same time the LED goes from red or green depending on when that button is pressed on the IR Remote. I can get both programs running separately and on the same sketch sheet, but I can't seem to get them both to work on the IR Remote. I haven't been able to find the right codes to get the stopwatch to work with the IR Remote and I know it can be done having seen youtube videos that don't show the codes and seeing other projects in the projects section doing a stopwatch with the LCD Screen and having it work that way, but I can't get my LCD Screen to work properly with any program so I'm using my 4 digit seven segment display.
