Stopwatch with Pause/Lap  6 digit 7 seg LED. HELP!
Warren, I put it up now as http://www.crossroadsfencing.com/stopwatch_22Jan.zip You should be able to download, unzip, and have a complete set of files now.
David, I think the new skeleton agress with I ended up with. I just didn't write it as functions. The main thing we started with was accurate 0.01 second intervals, the button pushes were incidental to that. If you take the stuff in tabs and copy them all end to end, it looks like what you have.
I found as the programs get bigger, it just gets harder & harder to keep track of what is going on with all the scrolling up & down.
I wonder if the new forum, which we get moved to tomorrow, will allow for bigger code listings? Seems to me thats its the comments which drive up the message size (limit of 9500 characters), yet without them code is pretty difficult to follow.
Robert
Warren, I don't think display speed will be a problem. Electricity moves fast! And you are only switching 20mA. If you read the datasheet, time is not mentioned anywhere. The 100's will be a blur, you may be able to make out the tenth' as they change at 10 times a second.
What have you ended up with for a power source?
Display speed wont be a problem.. when I said "they need to be read at fast speeds" I was referring to the digit size as they will be in pause mode when being read by the rider/driver.
I haven't sourced one yet.. I am going to use a power drill battery like you suggested before until I can find a good one. I want something slim so I can place it in the middle of the unit and try to keep everything balanced. :) I am going to download your zip now and report back shortly. :)
That link isn't working..?? Taking me to "Page Not Found"??? :-/
Hello Warren, please use right mouse button and click on Save target as... The file is all right.
Robert, thank you for your support. Idea is clear at this time. I am ready go up with accuracy - I need 0,001 in my aplication.
Repair: after downloading windows spoke to me that archive is either in unknow format or damage, I use for it WinRar, which have not problem with Zip. Robert which program you are used for it? All package has 1 252 bytes.
David, http://www.crossroadsfencing.com/stopwatch_22Jan/stopwatch_22Jan.zip
With windows vista, going to this link prompts me to open/save the file. What happens for you?
David, Should be doable - I use 100uS for my time check intervals:
unsigned long currentMicros = 0; // start of loop interval timer unsigned long previousMicros = 0; // end of interval? unsigned long hundred_uS_interval = 100; // = 0.1mS, use 1000 for 1mS : : // ******************************************************************************** // start timing interval // ********************************************************************************
currentMicros = micros(); // sample the time if (currentMicros - previousMicros >= hundred_uS_interval) // more than our interval? { // save the last time we okayed time updates previousMicros = currentMicros; // save the current time for next comparison toggle = 1-toggle; // -> 1-1, 1-0, 1-1, 1-0, results in 0 1 0 1 ...
// do stuff on 0.1mS intervals, 1mS intervals, ets.
I zipped it with this http://www.7-zip.org/
Hi Robert, I got it with this link;
but not this one;
I have downloaded and extracted the files fine this time using the new link address from Robert.
I will run it now and let you know how it works.
Warren
Yes, need the whole path :-)
Thank you Robert. I is running. So I will a little bit change code - output to LCD display and outputs to 485 net. I suppose, that I will not have problem. I suppose, that I will have also next parts for improovements - RTC, temperature.... So thanks again.
Robert... have I ever told you.. Your A STAR!!! [smiley=dankk2.gif] That is working fantastically!!!! brilliant! As you can imagine, I am over the moon!
The recall of the memory is working great. I will now have to add another button for 'memory_down' and then write something that will clear the memory when both buttons are pressed together.
You're very welcome Warren.
Why go down? Just hit reset and start readout from 0 again.
Well, if you must go down, replace the top of the memory_read code:
Lap# address1 address2 address3 address4 address5 address6 1 0 1 2 3 4 5 2 6 7 8 9 10 11 3 12 13 14 15 16 17 : : : : : : : 83 492 493 494 495 496 497 84 498 499 500 501 502 503 85 504 505 506 507 508 509 86 510 511 512 513 514 515 // adjust reset # in EEPROM_writing to be 516, from 512
//Memory
//Memory Up Button Here
memory_up_button_state = digitalRead (memory_up_button);
if ((memory_up_button_state == 0 && running == 0)|| EEPROM_reading_up == 1){ // not running - button pushed, or already reading
  if (EEPROM_reading_up == 0){
    EEPROM_reading_up = 1; // enable reading
    //Serial.println ("EEPROM reading up enabled ");
    delay (300); // or set up something with millis() to keep from double reads
//Memory Down Button Here (new code)
if ((memory_down_button_state == 0 && running == 0)|| EEPROM_reading_down== 1){ // not running - button pushed, or already reading
  if (EEPROM_reading_down == 0){
    EEPROM_reading_down = 1; // enable reading
    //Serial.println ("EEPROM reading down enabled ");
    if (EEPROM_address == 6){
EEPROM_address = 510:
    else{
      EEPROM_address = EEPROM_address -12;
if (EEPROM_reading_up == 1 || EEPROM_reading_down == 1){
  switch (byte_to_read){
continue with exisitng EEPROM reading code
If you want to write ( 255? ) to clear the memory with double button press & hold, then will have to come up with something like the pause button with case statements, add in code to read the EEPROM to know when to stop writing, etc. I was just thinking it would be neat to have the memory up or down button require 2 presses - 1st would display lap number (calculated from the start address being read), 2nd would display the time.
You have to update EEPROM_reading to EEPROM_reading_up & EEPROM_reading_down in presetup & in the stop/reset area as well, assign new pin #, etc.
Test reply.
That’s not supposed to happen!
To make the situation truly annoying, a few days ago I removed some spam from the "read only" area.
:D
Wow - how'd this thread get pulled oved from the old forum?
Let's continue here... http://arduino.cc/forum/index.php/topic,77658.msg586626.html#msg586626
Good idea - it's a bit spooky in here. XD
