Hi Codey, yes I have tried that.. I was originally timing it from my mobile phone but after all the controversy I though it would be a good idea to double/treble check how accurate it was.
I checked my mobile phone against my PC and it was accurate to it and then I checked the both of them against a hand held stopwatch/lap timer.. all 3 ran the same speed. My arduino is approx 4 weeks old and is an Arduino Uno.
if (ones_seconds == 10){
ones_seconds = 0;
[glow]hundredths = hundredths +7;[/glow] // Speed up the clock!
tens_seconds = tens_seconds +1;
Would this be acceptable as a fix? (shown previously)
Basically, if the Uno is out a little would it not be ok to give it a little back each loop? I don't want to bad code or anything like that but if the internal time is not accurate I don't see much choice in this situation.
Also please keep in mind that I am a complete novice with all this.
PS. Time difference after 1 hour = 11 seconds. :-[
Only you can decide. If what you are trying to build is "for entertainment purposes" then I can't imagine a little tweak being a problem. If money or pride is involved, you may end up involved in some heated arguments (or fights).
Certainly. But you should first confirm that your Arduino really does have a resonator instead of a crystal.
Yes, I agree.. lap times can become a very heated conversation at times.. I would certainly not like to be the guy who made the racer go slower...!!! >:( haha.. then you would see some fast laps as I left the building!! Lol.
If anyone reading this can shed any light on this.. please do otherwise I will try and get an answer from Arduino or someone else as soon as I can.
Thanx again to Robert and Codey for all your time and help. Really appreciated.
Warren,
I've adjusted it to use micros() instead millis() (ignore the names) and have it printing the time on screen once a second.
I downloaded a clock that CNET had a link to, to have something to watch that the PC updated once a second.
The screen update seems to update with no discernible change in rate, while the PC clock seems to catch up every once on a while - yet the two times are still in agreement after 37 minutes. Has not gained or lost any time.
I am wondering what I have that has more accurate time - maybe my Garmin Nuvi GPS? Have to see if the battery is charged and compare to that.
Have you decided if you have crystal, such as pictured here next to the USB connector,
or a resonator, which may look like the 3-lead blue part here
or this yellow part
unsigned long currentmillis = 0;
unsigned long previousmillis = 0;
unsigned long interval = 10000;
unsigned long elapsedmillis = 0;
byte latchpin = 2; // connect to pin 12 on the 74HC595
byte clockpin = 3; // connect to pin 11 on the 74HC595
byte datapin = 4; // connect to pin 14 on the 74HC595
byte testpin5 = 5;
byte ones_seconds = 0;
byte tens_seconds = 0;
byte ones_minutes = 0;
byte tens_minutes = 0;
byte tenths = 0;
byte hundredths= 0;
int segdisp[10] = {
63,6,91,79,102,109,125,7,127,111 }; //segment references using 74HC595 Shift Registers
//The above numbers light up different segments of a digit
byte time_update = 0;// added new flag
pinMode(latchpin, OUTPUT);
pinMode(clockpin, OUTPUT);
pinMode(datapin, OUTPUT);
pinMode(testpin5, OUTPUT);
Serial.begin(57600);
currentmillis = micros(); // read the time.
elapsedmillis = currentmillis - previousmillis;
if (elapsedmillis >= interval) // 10 milliseconds have gone by
previousmillis = previousmillis + elapsedmillis; // save the time for the next comparison
time_update = 1;
// if (elapsedmillis>10000){
// Serial.println (ones_seconds,DEC);
// Serial.println (elapsedmillis,DEC); I notice this prints out 10004 a lot, with an occasional 10008
if (time_update == 1){ // no updating if not at 10ms interval, skip this whole section
// increment the counters, roll as needed, shift the digits out
time_update = 0; // reset for next pass thru
hundredths = hundredths +1;
if (hundredths == 10){
hundredths = 0;
tenths = tenths +1;
if (tenths == 10){
tenths = 0;
ones_seconds = ones_seconds +1;
Serial.print ( tens_minutes,DEC);
Serial.print (ones_minutes,DEC);
Serial.print (tens_seconds,DEC);
Serial.println(ones_seconds,DEC);
ones_seconds = 0;
if (tens_seconds == 6){
tens_seconds = 0;
ones_minutes = ones_minutes +1;
if (ones_minutes == 10){
ones_minutes = 0;
tens_minutes = tens_minutes +1;
if (tens_minutes == 6){
tens_minutes = 0;
// counters are all updated now, just do the shiftout one time here:
digitalWrite(latchpin, LOW); // send the digits down to the shift registers!
shiftOut(datapin, clockpin, MSBFIRST, segdisp[hundredths]); // print the % first "hundredths" digit
shiftOut(datapin, clockpin, MSBFIRST, segdisp[tenths]); // print the tens of hundredths digit
shiftOut(datapin, clockpin, MSBFIRST, segdisp[ones_seconds]); // print the % first "seconds" digit
shiftOut(datapin, clockpin, MSBFIRST, segdisp[tens_seconds]); // print the tens of seconds digit
shiftOut(datapin, clockpin, MSBFIRST, segdisp[ones_minutes]); // print the % first "minute" digit
shiftOut(datapin, clockpin, MSBFIRST, segdisp[tens_minutes]); // print the tens of minutes digit
digitalWrite(latchpin, HIGH);
} // end if time to be updated
} // end void loop
Well, its been 2 hrs, 25 minutes, and my duemilanova seems to have gained about a second on the gov't time.
Will let it continue to run overnight & see what happens.
Got a feeling tho that my laptop will go into sleep mode or something, and reset the serial interface and lose track of where it is.
(2 / (((2 * 60) + 25) * 60)) * 1000000 = 229.885057 ppm (I think I have that correct)
...seems a bit high for a crystal.
I have a "Screen Saver Tool" that will help. When the screen saver is disabled, the tool also prevents the computer from going to sleep or hibernating. Essentially, it fools the operating system into believing a human is at the keyboard. If you're interested, send me a PM and we'll figure out a way to get you a copy.
Timer stayed alive overnight & serial port didn't reset!
Time comparison didn't change much - after running for nearly 8 hours (started at 1:00 AM with a 3 second time difference due a delay in opening the serial port and when the time actually appears on screen), the difference is still small, just 2 seconds.
Hi Robert and Codey,
I must be using the crystal clock going by the pictures you put up.. mine is the exact same as the first pic.
I have put your code in and tested it again and although better still runs slow.
I am testing again using another stopwatch and it is still showing a defecate of around 2 secs per 5 or 6 mins. :-/
Warren,
Did you try with the change to micros() instead of millis() ?
I let it run over night, was just 2-3 seconds off after 11 hours when I finally stopped.
Try checking it against the gov't time like I did, see how it looks.
Robert
Using the micros() instead of millis(). I tried it over approx 1 hour and it was (I think) 11 seconds out?? That was also on another stopwatch. I have used 4 different stopwatches up to now which all run the same. For some reason my Uno & code run slower?? However, when I add the 7 hundredths each loop it appears accurate to approx 1 sec per hour.
Just so there is no confusion, you have this exact Arduino...
So what does this mean??
If you float your mouse over the picture, you'll notice that there are labels. westfw believes that board has a RESONATOR, "Layout permits either resonator or crystal. Here we have a resonator (I think.)"
I assume I have a crystal.. does this mean it can't/won't be accurate with it's clock?
If your Arduion does have a resonator then that is very likely the reason why your Arduino's clock is "off".
But, all is not lost. You have some choices available...
You can make adjustments in software like you have been doing. I believe resonators are sensitive to temperature. If they really are then you will probably have to vary the adjustment a bit depending on the ambient temperature. In other words, you may have to calibrate your Arduino right before using it as a lap timer.
You may be able to carefully remove the resonator and replace it with a crystal. I have no idea if anyone has done this successfully or how difficult it may be.
You can use a "real time clock" (RTC). There are shields available that include an RTC. You could use something like this...
