Im working on creating a stopwatch for an lcd display. I found a great code although I’m not really sure who wrote it because the youtube video it was attached to did not say, but Im pretty sure the youtube poster wrote it because there is some customization to the account in the code. Anyways, when I run the sketch it works well but the stopwatch has a millis section that to me has no purpose and just takes up space on the lcd. The reason I want to get rid of it is because I want to add days to the stopwatch. I know how to do that and I know of course that I will still need the millis to be timed within the code but I just don’t want it to display. That is really the origin of my problem: I know that the millis is being used to calculate the rest of the times but I don’t know where it is being displayed within the sketch and how to separate the use of it, and the displaying of it. And by it I mean the millis value. Also, I’m not planning on timing anything for more than anywhere near the 50 day max that millis can record, will the value be cleared every time I restart the stopwatch? To be quite honest I’m not entirely sure whats going on with the modulo operator and the int casting and fractional int. It has helped, however; that the sketch is very well commented. I think this project might be a good way to expand into understanding those things.
Thanks a lot everyone!
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int ledPin = 13; // LED connected to digital pin 13
int buttonPin = 8; // button on pin 2
int value = LOW; // previous value of the LED
int buttonState; // variable to store button state
int lastButtonState; // variable to store last button state
int blinking; // condition for blinking - timer is timing
int frameRate = 100; // the frame rate (frames per second) at which the stopwatch runs - Change to suit
long interval = (1000/frameRate); // blink interval
long previousMillis = 0; // variable to store last time LED was updated
long startTime ; // start time for stop watch
long elapsedTime ; // elapsed time for stop watch
int fractional; // variable used to store fractional part of Frames
int fractionalSecs; // variable used to store fractional part of Seconds
int fractionalMins; // variable used to store fractional part of Minutes
int elapsedFrames; // elapsed frames for stop watch
int elapsedSeconds; // elapsed seconds for stop watch
int elapsedMinutes; // elapsed Minutes for stop watch
char buf[10]; // string buffer for itoa function
lcd.begin(16, 2); // intialise the LCD.
pinMode(ledPin, OUTPUT); // sets the digital pin as output
pinMode(buttonPin, INPUT); // not really necessary, pins default to INPUT anyway
digitalWrite(buttonPin, LOW); // turn on pullup resistors. Wire button so that press shorts pin to ground.
lcd.setCursor(0,0);
lcd.print(".............");
lcd.setCursor(0,1);
lcd.print("............");
void loop(){
digitalWrite(ledPin, LOW); // Initiate LED and Step Pin States
buttonState = digitalRead(buttonPin); // Check for button press, read the button state and store
// check for a high to low transition if true then found a new button press while clock is not running - start the clock
if (buttonState == LOW && lastButtonState == HIGH && blinking == false){
startTime = millis(); // store the start time
blinking = true; // turn on blinking while timing
delay(10); // short delay to debounce switch
lastButtonState = buttonState; // store buttonState in lastButtonState, to compare next time
// check for a high to low transition if true then found a new button press while clock is running - stop the clock and report
else if (buttonState == LOW && lastButtonState == HIGH && blinking == true){
blinking = false; // turn off blinking, all done timing
// Routine to report elapsed time
elapsedTime = millis() - startTime; // store elapsed time
elapsedMinutes = (elapsedTime / 60000L);
elapsedSeconds = (elapsedTime / 1000L); // divide by 1000 to convert to seconds - then cast to an int to print
elapsedFrames = (elapsedTime / interval); // divide by 100 to convert to 1/100 of a second - then cast to an int to print
fractional = (int)(elapsedFrames % frameRate); // use modulo operator to get fractional part of 100 Seconds
fractionalSecs = (int)(elapsedSeconds % 60L); // use modulo operator to get fractional part of 60 Seconds
fractionalMins = (int)(elapsedMinutes % 60L); // use modulo operator to get fractional part of 60 Minutes
lcd.clear(); // clear the LDC
if (fractionalMins < 10){ // pad in leading zeros
lcd.print("0"); // add a zero
lcd.print(itoa(fractionalMins, buf, 10)); // convert the int to a string and print a fractional part of 60 Minutes to the LCD
lcd.print(":"); //print a colan.
if (fractionalSecs < 10){ // pad in leading zeros
lcd.print(itoa(fractionalSecs, buf, 10)); // convert the int to a string and print a fractional part of 60 Seconds to the LCD
if (fractional < 10){ // pad in leading zeros
lcd.print(itoa(fractional, buf, 10)); // convert the int to a string and print a fractional part of 25 Frames to the LCD
else{
// run commands at the specified time interval
// blink routine - blink the LED while timing
// check to see if it's time to blink the LED; that is, the difference
// between the current time and last time we blinked the LED is larger than
// the interval at which we want to blink the LED.
if ( (millis() - previousMillis > interval) ) {
if (blinking == true){
previousMillis = millis(); // remember the last time we blinked the LED
digitalWrite(ledPin, HIGH); // Pulse the LED for Visual Feedback
elapsedMinutes = (elapsedTime / 60000L); // divide by 60000 to convert to minutes - then cast to an int to print
elapsedFrames = (elapsedTime / interval); // divide by 40 to convert to 1/25 of a second - then cast to an int to print
fractional = (int)(elapsedFrames % frameRate);// use modulo operator to get fractional part of 25 Frames
lcd.print(itoa((fractional), buf, 10)); // convert the int to a string and print a fractional part of 25 Frames to the LCD
else{
digitalWrite(ledPin, LOW); // turn off LED when not blinking
