For some reason the print of this code get me this:
AAA
AAA
AAA
AAB
ABC
What can be wrong?
In fact what I'm looking for are two functions to save/restore my struct by indexing several instances:
(Is like to have a struct mystruct[100] but not in RAM stored in EEPROM).
You can define it as a named struct, or a typedef, or both. In my opinion it is better to refer to the type using a typedef (so that it behaves consistently with the standard types and classes) in which case the struct name is redundant and it can be left anonymous. Others may have other preferences.
The code below defines a struct RoutingTableEntry - you can use struct RoutingTableEntry anywhere in your code that needs a type.
// defined as a struct
uint8_t dest;
uint8_t next_hop;
uint8_t state;
struct RoutingTableEntry myEntry;
The following code defines the struct RoutingTableEntry but also defines a typedef RoutingTableEntry. This means you can use RoutingTableEntry anywhere a type is needed; it is syntactically equivalent to struct RoutingTableEntry. The name of the struct and the typedef don't need to be the same, and some people prefer to make them different.
// defined as a typedef and a named struct
typedef struct RoutingTableEntry
uint8_t dest;
uint8_t next_hop;
uint8_t state;
} RoutingTableEntry ;
struct RoutingTableEntry myEntry1; // uses the struct declaration
RoutingTableEntry myEntry2; // uses the typedef
The following code defines the struct without giving it a name (it is left anonymous) and then defines a typedef for it the anonymous struct. This means that you can use RoutingTableEntry anywhere a type is needed.
// defined as a typedef and anonymous struct
typedef struct
uint8_t dest;
uint8_t next_hop;
uint8_t state;
// struct RoutingTableEntry myEntry1; // we didn't name the struct so we can't refer to it
RoutingTableEntry myEntry2; // uses the typedef to refer to the anonymous struct
Hi Peter!
The only way that I fount to get it work is this:
uint8_t dest; ///< Destination node address
uint8_t next_hop; ///< Send via this next hop address
uint8_t state; ///< State of this route, one of RouteState
} RoutingTableEntry;
I don't know why but the only way that I can pass the struct at the function call is declaring both times as RoutingTableEntry.
The code is working but it's wrote in the correct way?
I have others lines like this:
uint8_t RF22Router::route(RoutedMessage* message, uint8_t messageLen)
// Reliably deliver it if possible. See if we have a route:
uint8_t next_hop = RF22_BROADCAST_ADDRESS;
if (message->header.dest != RF22_BROADCAST_ADDRESS)
RoutingTableEntry* route = getRouteTo(message->header.dest);
if (!route)
return RF22_ROUTER_ERROR_NO_ROUTE;
next_hop = route->next_hop;
if (!RF22ReliableDatagram::sendtoWait((uint8_t*)message, messageLen, next_hop))
return RF22_ROUTER_ERROR_UNABLE_TO_DELIVER;
return RF22_ROUTER_ERROR_NONE;
I think that message->header.dest means that it evaluate the dest variable from the message's header rigth?
And this: next_hop = route->next_hop;
This loads the next_hop element...but where goes that value? looks that never store it?
its c++, the typedef on struct is really not necessary for specifying types.
RoutingTableEntry myObject;
you will also probably want to pass by reference not value, especially if you want the address of operator to return the original pointer not the one for the temporary
