LoboWin
October 16, 2017, 4:55pm
#1
Hi!
I working whit hc-sr04 sensors whit a rtc ds1302 clock all mounted on an Arduino Mega, my idea is when the sensor detect an object, show me a timestamp(hh:mm:ss) and keep it, then when object out of range, the timestamp variable(called hourIn) return to 0.
I was using Static variables but whit no success, maybe Arrays but i don’t know how to use them here
Here’s my code
#include <DS1302.h>
#include <Time.h>
#include <TimeLib.h>
#define echoPin 12 // Echo Pin
#define trigPin 13 // Trigger Pin
time_t t = now();
DS1302 rtc(6,20,21);
Static String hourIn;
setTime(t);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
void loop(){
long duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance <= 4) {
hourIn = rtc.getTimeStr();
Serial.println(hourIn);
else if (distance >= 5 || distance <= 0){
Serial.println("Out of range");
I appreciate any help, thanks!
I think it easier to:
detect the thing
save the timestamp
record in a bool isPresent = true.
if the thing leaves the area, change isPresent to false
If you like, make the two variables Global
If you want to make them persistent if there is a power-loss, you can save them to EEPROM
system
October 16, 2017, 5:04pm
#3
time_t t = now();
If you think you know what time it is, why do you need to call this function with that time?
setTime(t);
Where do you make that happen? hourIn is a lousy name for a String variable that hold more than the hour that some event happened at.
LoboWin
October 16, 2017, 7:13pm
#4
BulldogLowell:
detect the thing
save the timestamp
Sounds good and i dont need them pesistent, only keep it in the loop when IF is correct. Now i am not home for testing
PaulS:
Your right, i forgot delete them cuz the original code is too long
PaulS:
Really, when is Else lost their If timestamp and get current time again
