Hello.
I would like to store the MPU's angle value in an array, but I dont know how to start it.
I have a code where I calculate the angle around Y axis, and from this values in a given time I'd like to calculate an average.
Here is my code, where I calculate the angle and send the values to another ESP. I would like to send the average angle.
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <Wire.h>
#include <espnow.h>
int16_t Acc_rawX, Acc_rawY, Acc_rawZ,Gyr_rawX, Gyr_rawY, Gyr_rawZ;
const int MPU = 0x68;
float Acc_angle_X, Acc_angle_Y;
float Gyro_angle_X, Gyro_angle_Y;
float Angle_X, Angle_Y;
float elapsedTime, t, timePrev;
float rad_to_deg = 180/3.141592654;
//reciever MAC address
uint8_t broadcastAddress[] = {0x98, 0xF4, 0xAB, 0x6C, 0x57, 0xC4};
void OnDataSent(uint8_t *mac_addr, uint8_t sendStatus) {
Serial.print("Last Packet Send Status: ");
if (sendStatus == 0){
Serial.println("Delivery success");
else{
Serial.println("Delivery fail");
Wire.begin();
Wire.beginTransmission(MPU);
Wire.write(0x6B);
Wire.write(0);
Wire.endTransmission(true);
WiFi.mode(WIFI_STA);
// Init ESP-NOW
if (esp_now_init() != 0) {
Serial.println("Error initializing ESP-NOW");
return;
// Once ESPNow is successfully Init, we will register for Send CB to
// get the status of Trasnmitted packet
esp_now_set_self_role(ESP_NOW_ROLE_CONTROLLER);
esp_now_register_send_cb(OnDataSent);
// Register peer
esp_now_add_peer(broadcastAddress, ESP_NOW_ROLE_SLAVE, 1, NULL, 0);
t = millis();
void loop(){
// Accelerometer data //
Wire.write(0x3B); //Ask for the 0x3B register- correspond to AcX
Wire.endTransmission(false);
Wire.requestFrom(MPU,6,true);
Acc_rawX=Wire.read()<<8|Wire.read(); //each value needs two registres
Acc_rawY=Wire.read()<<8|Wire.read();
Acc_rawZ=Wire.read()<<8|Wire.read();
/*---X---*/
Acc_angle_X = atan((Acc_rawY/16384.0)/sqrt(pow((Acc_rawX/16384.0),2) + pow((Acc_rawZ/16384.0),2)))*rad_to_deg;
/*---Y---*/
Acc_angle_Y = atan(-1*(Acc_rawX/16384.0)/sqrt(pow((Acc_rawY/16384.0),2) + pow((Acc_rawZ/16384.0),2)))*rad_to_deg;
// Gyroscope data //
timePrev = t;
t = millis();
elapsedTime = (t - timePrev) / 1000;
Wire.write(0x43); //Gyro data first adress
Wire.requestFrom(MPU,4,true); //Just 4 registers
Gyr_rawX=Wire.read()<<8|Wire.read();
Gyr_rawY=Wire.read()<<8|Wire.read();
/*---X axis angle---*/
Angle_X = 0.98 *(Angle_X + Gyro_angle_X*elapsedTime) + 0.02*Acc_angle_X;
/*---Y axis angle---*/
Angle_Y = 0.98 *(Angle_Y + Gyro_angle_Y*elapsedTime) + 0.02*Acc_angle_Y;
Serial.print("Angle: ");
Serial.println(Angle_Y);
esp_now_send(broadcastAddress, (uint8_t *) &Angle_Y, sizeof(Angle_Y));
My idea was that, write the obtained values into an array, then averaged the array's element, and send it. But unfortunately I've never worked with arrays.
Thanks in advance!
