Store array for later submission
Hello.
I'm having trouble understanding how I could do to store a QUERY if the database connection is interrupted.
My project consists of saving every 10 seconds a value in the database, and if the connection with the database drops, this query must be stored in the queue for sending when the network returns, thus creating a pending send queue.
I currently use the code below with ChuckBell's lib.
#include <Ethernet.h>
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
byte mac_addr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server_addr(10, 0, 1, 35); // IP of the MySQL *server* here
char user[] = "****";              // MySQL user login username
char password[] = "****";        // MySQL user login password
int status_db; // variable that receives bank status, 0 for not available and 1 for available.
int val_1, val_2, val_3, val_4;
int maq = 100;
unsigned long millisTask1 = millis();
//Analog Input
#define ANALOG_PIN_0 35
#define ANALOG_PIN_1 34
#define ANALOG_PIN_2 36
#define ANALOG_PIN_3 39
// Query
char INSERT_SQL[] = "INSERT INTO db.test (maq,val_1,val_2,val_3,val_4) VALUES ('%d','%d','%d','%d','%d')";
char query[512];
EthernetClient client;
MySQL_Connection conn((Client *)&client);
  while (!Serial);
  Ethernet.begin(mac_addr);
  Serial.println("Connecting...");
  func_connect_db();
  // function to check database connection
  func_connect_db();
  // receiving values in the variables...
  val_1 = analogRead(ANALOG_PIN_0);
  val_2 = analogRead(ANALOG_PIN_1);
  val_3 = analogRead(ANALOG_PIN_2);
  val_4 = analogRead(ANALOG_PIN_3);
  // millis to run every 10s
  if ((millis() - millisTask1) < 10000)
    if (status_db == 1) // if database is available...
      func_post(); // function that executes the query
    if (status_db == 0) // if database unavailable...
      // at this point it creates the query queue to send when the connection comes back.
void func_connect_db()
  if (conn.connect(server_addr, 3306, user, password))
    status_db = 1;
    Serial.println("Connection failed.");
    status_db = 0;
void func_post()
  sprintf(query, INSERT_SQL, maq, val_1, val_2, val_3, val_4);
  MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
  cur_mem->execute(query);
  delete cur_mem;
Have you done the calculations how much memory will be required if connection to the DB failed for one day? Does your board have enough RAM for that? You might have to opt for a bigger storage.
To answr the question, I suggest that you use a struct (or class) to store the 4 associated values; below uses a struct.
// a struct to store the measurements
struct MEASUREMENT
  int value1;
  int value2;
  int value3;
  int value4;
// array to store one hour worth of measurements
MEASUREMENT measurements[360];
// where to store in array
uint16_t measurementIndex;
    // save to array
    measurement[measurementIndex].value1 = val_1;
    measurement[measurementIndex].value2 = val_2;
    measurement[measurementIndex].value3 = val_3;
    measurement[measurementIndex].value4 = val_4;
    measurementIndex++;
It will probably be easier if you store the measurements directly in the measurements array and send the data that is stored in the array
  func_connect_db();
  // if there is still space in the measurements array
  if (measurementIndex < sizeof(measurements) / sizeof(measurements[0]))
    // store
    measurements[measurementIndex].value1 = analogRead(ANALOG_PIN_0);
    measurements[measurementIndex].value2 = analogRead(ANALOG_PIN_1);
    measurements[measurementIndex].value3 = analogRead(ANALOG_PIN_2);
    measurements[measurementIndex].value4 = analogRead(ANALOG_PIN_3);
    measurementIndex++;
    // for each stored set of measurements
    for (uint16_t cnt = 0; cnt < measurementIndex; cnt++)
      func_post(uint16_t index);
    // reset measurement index
    measurementIndex = 0;
And the func_post() needs a modification to take a number indicating which record to send.
void func_post(uint16_t index)
  sprintf(query, INSERT_SQL, maq, measurements[index].value1, measurements[index].value2, measurements[index].value3, measurements[index].value4);
  delete cur_mem;
Notes:
  1. problems might arise if the DB connection fails while transfering data as measurementIndex is only reset once all records are transmitted. Better solution would be to use a FIFO or queue.
  2. not tested nor compiled
Hi Sterretje;
I'm using ESP32.
Thanks for the tips, I'll do the tests with this code.
About FIFO, what would the code look like?
Never actually thought about it; I would place in the array and after every succesful submit of one record, move all records one up using memmove; or use two pointers, one for the head and one for the tail.
Maybe CircularBuffer - Arduino Reference might be useful.
thanks for the feedback.
I know, not much help with the original issue but a comment of a potential issue. That could cause data transmission loses.
As can be seen at the end of setup() the function to connect to db is run. Going from setup the db connection function is run again. I recommend only running connect to the db once instead of trying to open a connection when a connection may be already open, network stack corruption will occur.
I'd have func_connect_db() issue a disconnect before making a connection to prevent stack issues.
Hello,
This function checks the connection, and if the connection is dropped it reconnects. It does not make a connection again if it is still connected.
You can also design your application in such a way that the data you read from the analog pins is always first queued.
You'd use a struct / array to represent the analog readings and periodically collect and queue these.
You'd have another task which checks regularly if there is an item in the queue and that the connection is available and, if so, removes the first item from the queue and sends it to the server.
It would be a small modification of what @sterretje has already presented.
I have a light weight queue which uses a template to queue arbitrary structures and it might be useful here. There is an example of it in this thread: Problem in order of execution of functions - #53 by 6v6gt
