Hello,
I declare theses arrays on the beginning sketch file:
uint8_t mac_addr_Server1[6] = {0x34, 0xb4, 0x72, 0x4d, 0x63, 0xc6 };
uint8_t mac_addr_Server2[6] = {0xb0, 0x7e, 0x11, 0xdd, 0xc7, 0x97 };
uint8_t mac_addr_Server_Used[6];
How can i set mac_addr_Server_Used=mac_addr_Server1 on the beginning?
Thank you.
Do this in setup()
memcpy(mac_addr_Server_Used, mac_addr_Server1, sizeof(mac_addr_Server1));
J-M-L
3
Alternatively - If you use a Struct with an array inside then you can just use = for assignment
You could also have the known Mac addresses in a 2D array and only keep the index of the currently used one, that would save some memory
const uint8_t macs[][6] = {
{0x34, 0xb4, 0x72, 0x4d, 0x63, 0xc6 },
uint8_t macIndex = 0;
How do you set macs[macIndex][6] to array [6] ?
J-M-L
5
I don’t get the question…
How do you select array at macIndex position ?
How do you print this array?
for (int x = 0; x < 6; x++)
Serial.println(macs[macIndex][x], HEX);
J-M-L
8
macs[macIndex]
is a pointer to the start of the array.
system
Closed
9
