I have some sensors (analog and digital) taking measurements of temperature, humidity, etc., and I would like to save their data on the computer (for example TIME: MINUTE - DATA). The Arduino is connected via USB. I researched some things, but I didn't find a "simple" or efficient way .. would anyone know how to help me?
Tenho alguns sensores (analógicos e digitais) fazendo medições de temperatura, umidade etc, e gostaria de salvar os dados deles no computador (por exemplo HORA:MINUTO - DADO). O Arduino fica conectado pelo USB. Pesquisei algumas coisas, mas não achei uma maneira "simples" ou eficiente.. alguém saberia me ajudar?
#include <DHT.h>;
#include <Wire.h>
#include <OneWire.h> //INCLUSÃO DE BIBLIOTECA
#include <DallasTemperature.h> //INCLUSÃO DE BIBLIOTECA
#define DHTPIN 7 //PINO DIGITAL UTILIZADO PELO DHT22
#define DHTTYPE DHT22 //DEFINE O MODELO DO SENSOR (DHT22 / AM2302)
#define DS18B20 6 //DEFINE O PINO DIGITAL UTILIZADO PELO SENSOR
DHT dht(DHTPIN, DHTTYPE); //PASSA OS PARÂMETROS PARA A FUNÇÃO
OneWire ourWire(DS18B20); //CONFIGURA UMA INSTÂNCIA ONEWIRE PARA SE COMUNICAR COM O SENSOR
DallasTemperature sensors(&ourWire); //BIBLIOTECA DallasTemperature UTILIZA A OneWire
int UVOUT = A0; //Output from the sensor
int REF_3V3 = A1; //3.3V power on the Arduino board
void setup(){
Serial.begin(9600); //INICIALIZA A SERIAL
pinMode(UVOUT, INPUT); //ML8511
pinMode(REF_3V3, INPUT); //ML8511
dht.begin(); //INICIALIZA A FUNÇÃO DHT22
sensors.begin(); //INICIA O SENSOR DS18B20
delay(2000); //INTERVALO DE 2 SEGUNDO ANTES DE INICIAR
void loop(){
Serial.print("DHT22: ");
Serial.print("Umidade: "); //IMPRIME O TEXTO NA SERIAL
Serial.print(dht.readHumidity()); //IMPRIME NA SERIAL O VALOR DE UMIDADE MEDIDO
Serial.print("%"); //IMPRIME O TEXTO NA SERIAL
Serial.print(" / Temperatura: "); //IMPRIME O TEXTO NA SERIAL
Serial.print(dht.readTemperature(), 2); //IMPRIME NA SERIAL O VALOR DE UMIDADE MEDIDO E REMOVE A PARTE DECIMAL
Serial.println("*C"); //IMPRIME O TEXTO NA SERIAL
Serial.print("DS18B20: ");
sensors.requestTemperatures();//SOLICITA QUE A FUNÇÃO INFORME A TEMPERATURA DO SENSOR
Serial.print("Temperatura: "); //IMPRIME O TEXTO NA SERIAL
Serial.print(sensors.getTempCByIndex(0)); //IMPRIME NA SERIAL O VALOR DE TEMPERATURA MEDIDO
Serial.print("ML8511: ");
int uvLevel = averageAnalogRead(UVOUT);
int refLevel = averageAnalogRead(REF_3V3);
//Use the 3.3V power pin as a reference to get a very accurate output value from sensor
float outputVoltage = 3.3 / refLevel * uvLevel;
float uvIntensity = mapfloat(outputVoltage, 0.99, 2.9, 0.0, 15.0);
Serial.println("uvLevel=" + (String)uvLevel + " ");
Serial.println("voltage=" + (String)outputVoltage + " ");
Serial.println("uv=" + (String)uvIntensity + "(mW/cm^2)");
Serial.println("------------------------------");
delay(2000); //INTERVALO DE 2 SEGUNDOS * NÃO DIMINUIR ESSE VALOR (DHT22)
//Takes an average of readings on a given pin
//Returns the average
int averageAnalogRead(int pinToRead)
byte numberOfReadings = 8;
unsigned int runningValue = 0;
for(int x = 0 ; x < numberOfReadings ; x++)
runningValue += analogRead(pinToRead);
runningValue /= numberOfReadings;
return(runningValue);
//The Arduino Map function but for floats
float mapfloat(float x, float in_min, float in_max, float out_min, float out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Tks!
