Store data to SD-Card with specific structure
Hi.
I´m getting data from a A/D at 40SPS connected to a laptop, but i wish to store it in a SD-Card, to do some field tests. The issue is: i need to store the data to make it compatible with a software i use to plot the data, with the following structure:
-The software receives the ASCII data and stores in a *.Z file.
-It stores the data in a *.Z file per hour, one folder per day..but to make it easy, doesnt need to create folders: 0.z ; 1.z...15.z; 16.z...; 26.z;...; 30.z....
-Every Z file has a 4 byte header which tells how long the file is in samples.
-After the 4 byte header, it stores data in 16bit short words (1 sample, 1 16bit short word?).
-The *.Z file covers an entire hour so when reading it, the program figures out the sample rate by dividing the number of samples by 3600.
Before starting on the SD-Card to store the data, will the Arduino be able to work on the A/D code and save the data to a SD-Card?
If the Arduino be able to do this, how can programme it to store the data following that structure?
I aprecciate any help. If it helps, i can share some Z files.
Thanks.
Yes, if your specification is complete, the Arduino is able to fulfill your requirements.
I would read the values for perhaps a second, open the correct file, write all 40 values and close the file. Even better would be to get 256 values and store them because that fills a sector on the SD card and it will no die that fast. To write an integer use this:
int value;
file.write(&value, sizeof(value));
For the long value (4 bytes) you do the same with the other type:
uint32_t size;
file.write(&size, sizeof(size));
