Store Keypas Pass in char* variable
Hello Guys,
I'm new to arduino and i'm looking to do a function to store or append the pressed keys on a keypad inside a char variable.. is this possible?
Here's what i'm doing:
void newPassJVC(KeypadEvent eKey){
  char *newKey;
  switch (keypad.getState()){
  case PRESSED:
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print(eKey);
    switch (eKey){
    case '*':
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print(newKey);
      jvc.set(newKey);
    case '#':
      lcd.clear();
      lcd.print("Cancelar...");
      currentPosition = -1;
      displayCodeEntryScreen();
    default:
      newKey += eKey;
It clearly isn't working..
Thanks in advance!
Regards,
Jesus
Of course not. newKey is a pointer. What does it point to? You haven't made it point to anywhere where you can store data.
      newKey += eKey;
Incrementing a pointer that points nowhere doesn't make sense.
Before you start trying to use pointers to do this, work on storing data in a char array, first.
