store more then 64k on progmem
how can i store more then 64kb of data (arrays) on an arduino mega2560 using progmem?
i need to find a way to address the next 64kb but how? is this possible with arduino? i know that it is theoretically possible with the atmega2560
maybe you're looking for this - http://ruggedcircuits.com/blog/ - http://ruggedcircuits.com/html/megaram.html - ?
That's pretty cool, adding such a large RAM to an arduino. Couple of questions though. First of all, how does it work? Any schematics, or PCB layouts? Also, what projects would benefit from that much extra memory? Is it ever actually needed?
Onions.
that ram is cool! but i need something to sore the data permanently, like on a sd card. but on the flash memory of the atmega.
i am doing that with progmem, but i don't know how to break thou the 64kb wall.
For each pgm_read_xxx_near function, there is also a corresponding pgm_read_xxx_far function that takes a 32 bit address as input. That should be all that's necessary to handle more than 64k of progmem.
One thing note though, all the progmem compatible functions provided by AVR Libc only work with the lower 64k of progmem.
For reference: avr-libc: <avr/pgmspace.h>: Program Space Utilities
volkerracho:
Another thing to note, progmem can only be written as part of source code compilation and download. It cannot be written at runtime. If you need to store data while running, you'll have to use some other method (such as an sd card, or expanded eeprom).
Onions:
The AVR mega1280/2560 chips have internal hardware to support external SRAM memory built into them. You can check the AVR datasheet for all the details http://www.atmel.com/dyn/resources/prod_documents/doc2549.pdf.
http://ruggedcircuits.com/AD190/ad190.pdf
Any projects requiring more SRAM then the chips presesently have.
Seldom is there ever only one solution to a problem, but having more SRAM could make some problem much
easier to solve.
Onions.
jraskell:
thanks for the information, but what dose that mean? is it possible or not?
Onions:
Onions.
I've been thinking of getting one to add onto my Arduino Mega powered rover and play around with an onboard SLAM navigation system.
volkerracho:
jraskell:
It means you can write to and read from memory locations > 64k, but you can't utilize any of the progmem compatible functions like strlen_P, memcpy_P, etc. on data stored in memory locations > 64k. You'd have to implement any of that functionality you want to use in your own code.
Yes, it is possible. You just can't utilize any of the existing helper function to make progmem usage easier.
ok, that information helps!
what i still don't understand is: how do i write "far".
there are only functions for reading "far"
i guess i am totally misunderstanding something here...
Progmem is read only, that's why there are only read function.
volkerracho:
progmem is 'written' into your source code. In other words, you create more than 64k worth of data in your source code, and use the 'far' functions to read and utilize that data.
As I said previously, you cannot write to progmem at runtime.
ok, but somehow the data need to get on the flash memory, while the new program is uploaded. how do i decide if its gets in the first "near" 64kb or in the 2nd "far" 64kb space?
i don't want to write while the program is running.
Just use 'far', it addresses all memory.
ok, so it gets stored automatically "far" as soon as the "near pointer" is full.
thanks!
volkerracho:
thanks!
No. It only uses one pointer that is 32 bits. The far is just a label is doesn't indicate any actual distance restrictions.
The near functions use a 16 bit pointer, which can only address up to 64k of address space.
The far functions use a 32 bit pointer, which can not only address the same 64k of address space, but also an additional 4gb of address space.
There is no transition from one pointer to another.
The reason their are separate functions for 16bit and 32bit access is because there is more overhead in terms of code space and execution time when using 32bit pointers, so 16bit pointers should be used unless 32bit pointers are required (ie when there is more than 64k of progmem to access).
ok, so it should work when i use always read_far.
but it doesn't!
as soon as the program size gets bigger then 64kb the whole program is not working and the arduino is doing nothing.
after deleting some of the data it works again.
here is the code:
#ifndef DATA_CPP
#define DATA_CPP
#include <WProgram.h>
#include <avr/pgmspace.h>
#include "Data.h"
#if !defined(ARRAY_SIZE)
    #define ARRAY_SIZE(x) (sizeof((x)) / sizeof((x)[0]))
#endif
/* all our feaky fucking position data */
static const prog_uint16_t PGMScene01[] PROGMEM = { ................................ data is nomally here but it was to much for this post................
static const prog_uint16_t PGMScene02[] PROGMEM = { ................................ data is nomally here but it was to much for this post................
static const prog_uint16_t PGMScene03[] PROGMEM = { ................................ data is nomally here but it was to much for this post................
const prog_uint16_t* PGMScenes[] = { PGMScene01, PGMScene02, PGMScene03, PGMScene04, PGMScene05, PGMScene06, PGMScene07, PGMScene08, PGMScene09, PGMScene10, PGMScene11, PGMScene12, PGMScene13, PGMScene14, PGMScene15, PGMScene16 };
const unsigned int PGMFrameLengths[] = { 972, 895, 559, 1413, 660, 746, 688, 334, 572, 294, 549, 484, 3079, 948, 531, 1697 };
Data data;
void Data::setup() {
  verbose           = true;
  interpolating     = false;
  scene_count       = ARRAY_SIZE(PGMScenes);
  frame_count       = 0;
  scene_pos         = -1;
  frame_pos         = -1;
  point[0] = point[1] = point[2] = 0; // _x _y _z
  frame[0] = frame[1] = frame[2] = frame[3] = frame[4] = 0; //_scene _frame _x _y _z
  frames_in_between = 44; //leere frames zwischen zwei scenen
  frames_at_start   = 70; //leere frames am anfang des filmes
  lscene_lframe[0] = lscene_lframe[1] = lscene_lframe[2] = 0;
  tscene_fframe[0] = tscene_fframe[1] = tscene_fframe[2] = 0;
  tframe[0] = tframe[1] = tframe[2] = 0;
  if (verbose) {
/* triggers the next scene
 * at the beginning of a scene go first in transition mode by substracting
 * frames_in_between or frames_at_start from the frame_pos
int Data::nextScene() {
  if(scene_count - 1 > scene_pos) {
    scene_pos++;
    last_frame_pos = frame_pos;
    frame_pos = (scene_pos == 0) ? -frames_at_start-1 : -frames_in_between-1;
    frame_count = PGMFrameLengths[scene_pos];
    if (verbose) {
      Serial.print("Scene: "); Serial.println(scene_pos);
      Serial.print("Frame: "); Serial.println(frame_pos);
      Serial.print("Framecount: "); Serial.println(frame_count);
      Serial.print("Scenecount: "); Serial.println(scene_count);
  return scene_pos;
/* triggers the next frame and fills the position array
int Data::nextFrame() {
  if(frame_pos < frame_count - 1 ) {
    frame_pos++;
    //Serial.print("Frame Pos: "); Serial.println(frame_pos);
    if(frame_pos >= 0) { // only if we'r not in the scene transition mode
      if(scene_pos != 12) {
        tframe[0] = pgm_read_word_far( PGMScenes[scene_pos] + (frame_pos * 3) + 0 );
        tframe[1] = pgm_read_word_far( PGMScenes[scene_pos] + (frame_pos * 3) + 1 );
        tframe[2] = pgm_read_word_far( PGMScenes[scene_pos] + (frame_pos * 3) + 2 );
      }else{
        tframe[0] = pgm_read_word_far( PGMScene13 + (frame_pos * 3) + 0 );
        tframe[1] = pgm_read_word_far( PGMScene13 + (frame_pos * 3) + 1 );
        tframe[2] = pgm_read_word_far( PGMScene13 + (frame_pos * 3) + 2 );
    } else if(scene_pos != 0 && scene_pos != -1) { // here we'r in transition mode
      /* get the last frame from last scene (lscene_lframe) and the first frame from this
       * scene (tscene_fframe) for transition
      //int frame_count_last_scene =  (PGMFrameLengths[scene_pos - 1]) - 1;
      int frame_count_last_scene = last_frame_pos; // get the framepos from last scene before jumping into interpolation mode
		  if(scene_pos - 12 != 1 ) {
        lscene_lframe[0] = pgm_read_word_far( PGMScenes[scene_pos-1] + (frame_count_last_scene * 3 + 0) );
        lscene_lframe[1] = pgm_read_word_far( PGMScenes[scene_pos-1] + (frame_count_last_scene * 3 + 1) );
        lscene_lframe[2] = pgm_read_word_far( PGMScenes[scene_pos-1] + (frame_count_last_scene * 3 + 2) );
        lscene_lframe[0] = pgm_read_word_far( PGMScene13 + (frame_count_last_scene * 3 + 0) );
        lscene_lframe[1] = pgm_read_word_far( PGMScene13 + (frame_count_last_scene * 3 + 1) );
        lscene_lframe[2] = pgm_read_word_far( PGMScene13 + (frame_count_last_scene * 3 + 2) );
        tscene_fframe[0] = pgm_read_word_far( PGMScenes[scene_pos] + 0 );
        tscene_fframe[1] = pgm_read_word_far( PGMScenes[scene_pos] + 1 );
        tscene_fframe[2] = pgm_read_word_far( PGMScenes[scene_pos] + 2 );
        tscene_fframe[0] = pgm_read_word_far( PGMScene13 + 0 );
        tscene_fframe[1] = pgm_read_word_far( PGMScene13 + 1 );
        tscene_fframe[2] = pgm_read_word_far( PGMScene13 + 2 );
      /* interpolate between these two points */
      interpolate(lscene_lframe, tscene_fframe, tframe, frames_in_between + frame_pos);
      interpolating = true;
    } else { // here we'r at the beginning of the film - send 70. times zero
      tframe[0] = 0; tframe[1] = 0; tframe[2] = 0;
    /* fill the frame and position aka point arrays */
    point[0] = tframe[0]; point[1] = tframe[1];	point[2] = tframe[2];
    frame[0] = scene_pos;  frame[1] = frame_pos; frame[2] = tframe[0]; frame[3] = tframe[1]; frame[4] = tframe[2];
  return frame_pos;
/* returns count of scenes */
int Data::getSceneCount() {
  return scene_count;
/* returns count of frames of actual active scene */
int Data::getFrameCount() {
  return frame_count;
/* returns frameposition in actual scene */
int Data::getFramePos() {
  return frame_pos;
/* returns the camera position of the actual frame as Array() */
long* Data::getPosition() {
  return point;
/* returns the actual frame (_scene_pos, _frame_pos, _x, _y, _z)
 * --> simmilar to getPosition();
long* Data::getFrame() {
  return frame;
/* resets everything including scene_pos and frame_pos -> back to the start */
void Data::reset() {
  scene_pos   = -1;
  frame_pos   = -1;
  frame_count = 0;
/* returns if the mashine is interpolating right now */
bool Data::isInterpolating() {
  return interpolating;
int Data::availableMemory()
  int size = 1024;
  byte *buf;
  while ((buf = (byte *) malloc(--size)) == NULL);
  free(buf);
  return size;
/* private stuff */
void Data::interpolate(long from[3], long to[3], long dst[3], int in_stack)
  float mu = ( float(in_stack) / float(frames_in_between) );
  int tx = round(CosineInterpolate(float(from[0]), float(to[0]), mu));
  int ty = round(CosineInterpolate(float(from[1]), float(to[1]), mu));
  int tz = round(CosineInterpolate(float(from[2]), float(to[2]), mu));
  dst[0] = tx; dst[1] = ty; dst[2] = tz;
float Data::CosineInterpolate(float y1, float y2, float mu) {
  float mu2;
  mu2 = (1.0-cos(mu*PI))/2.0;
  return(y1*(1.0-mu2)+y2*mu2);
#endif
actually the edge is not 64kb it is 73000bytes
if the program size is bigger then 73000bytes it stops working.
why?????????????????
i still don't get it to work. is there any working example program somewhere that manages to store more then 64kb of data?
that would help a lot!
