Hey guys I am getting some data in the form of arrays and I need to store the data in another array, to send the data at certain time (say counter == 10) or at time == 1000 ms.
I do not know how many arrays I get.
My use case is that I am getting data arrays every minute for 10 sec, and I need to store the data and send the whole data which will be a single array with unknown length, every 10 minutes.
Kindly suggest what is the best way to do this, I appreciate your suggestions.
main loop(){
for (int i=0;i<30;i++){
devices[j++]=array1*;*
}* } Then I need to send devices via UART, and this "devices" contains other arrays' data that I need to store and later send. But this is not giving me anything, and if I changed devices[j++] to devices then I get only first array data. Any suggestions will be appreciated. Thanks and Regards,
Can you explain if you need to store all the arrays ? What Arduino do you use ?
Please correct your post above so that italic goes away.. add code tags around your code: [code]`` [color=blue]// your code is here[/color] ``[/code].
It should look like this:// your code is here
(Also press ctrl-T (PC) or cmd-T (Mac) in the IDE before copying to indent your code properly)
