Store my sensor data in specific location
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
#include <SoftwareSerial.h>
Adafruit_SSD1306 display(OLED_RESET);
SoftwareSerial BTserial(0,1);
int analogInput = A0;
int led1=8;
int led2=9;
int led3=10;
const int sampleWindow = 50;
unsigned int sample;
const int noise=A1;
void setup(){
  BTserial.begin(9600);
  pinMode(analogInput, INPUT);
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  display.clearDisplay();
void loop(){
  unsigned long startMillis = millis();
  unsigned int PeaktoPeak = 0;
  unsigned int SignalMax = 0;
  unsigned int SignalMin = 1024;
  while ( millis() - startMillis < sampleWindow ){
    sample = analogRead(analogInput);
    if (sample < 1024) {
      if (sample > SignalMax){
        SignalMax = sample;
      else if (sample < SignalMin){
        SignalMin = sample;
  PeaktoPeak = SignalMax - SignalMin;
  float MeterValue = ( PeaktoPeak * 3.3 /675) * 10;
  int change = map(MeterValue, 0, 1023, 0, 255);
  analogWrite(noise, change);
  Serial.println(MeterValue*10);
  BTserial.println(MeterValue*10);
  int a =MeterValue*10;
    char temp_buff[5];
    char temp_disp_buff[11] = "Sound:";
    dtostrf(a,2,1,temp_buff);
    strcat(temp_disp_buff,temp_buff);
    display.setTextSize(2);
    display.setTextColor(WHITE);
    display.setCursor(0,0);
    display.println(temp_disp_buff);
    display.display();
 if(a < 30)
  digitalWrite(led1,HIGH);
  digitalWrite(led2,LOW);
  digitalWrite(led3,LOW);
  Serial.println("Sound is Low");
 else if((a>30) && (a<=90))
  digitalWrite(led1,LOW);
  digitalWrite(led2,HIGH);
  Serial.println("Sound is Moderate");
 else if(a>90)
  digitalWrite(led3,HIGH);
  Serial.println("Sound is High");
HI,
wireless Sound Meter
This is my sound sensor code. Function of my project is sense the sound value and convert analog to digital , after conversion i send the digital data of sound in dB to android via bluetooth HC-05 and OLED 0.96''. But i need to store sound data in specific location arduino like i want to use only my apk with arduino, Like i want specify where the sensor data available.
for example in Ruuvi sensor , there is multiple parameters are measured and transferred to android via Bluetooth. They specify each parameters in HEX address in both android and microcontroller like for temperature value -127c - 127c from 0x04 to 0x17, like the same i want to allocate specific loaction for my data 0dB to 128dB . PLEASE HEPL ME WITH YOUR IDEA
This is an Arduino forum... Are you using an Arduino?
yes i'm arduino
You need to explain better what you are trying to do. I honestly have no idea.
Hello gajm07
Take some time and describe the desired function of the sketch in simple words and this very simple.
Sorry , i updated details now
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to [url=https://forum.arduino.cc/index.php?topic=710766.0]Learn How To Use The Forum[/url].
Other general help and troubleshooting advice can be found here.
