Im trying to make a art installation piece that basically is a small box that you can knock a beat on and it will bounce about (via solenoids "a bit like the jumping toaster in ghostbusters2") at same beat you knocked it.
I've got a piezo waiting on the solenoids from ebay and transistors to control the solenoids, but not to great at the whole programming bit.
So far I have an led blinking when the piezo is knocked
/*piezo sketch *lights and LED when Piezo is tapped */ const int sensorPin = 0; // the analog pin connected to the sensor const int ledPin = 13; // pin connected to LED const int THRESHOLD = 100; void setup() { pinMode(ledPin, OUTPUT); } void loop() { int val = analogRead(sensorPin); if (val >= THRESHOLD) { digitalWrite(ledPin, HIGH); delay(100); // to make the LED visible } else digitalWrite(ledPin, LOW); }
now I could get that to trigger the solenoid as soon as its been knocked, but I would like to store a beat of knocks then wait if their are any more for 5 or so seconds then output them to the solenoids.
/*piezo sketch
const int solPin = 10; // pin connected to transistor-solenoid
long timing_rythm[10] = 0; // 10 beat, could be more;
int count = 0;
int play = 0;
pinMode(solPin, OUTPUT);
if ( !play ) {
timing_rythm[count] = millis();
count++;
if (count == 10) count = 0;
if( (millis() - timing_rythm[count]) > 5000 ) play = 1;
if (play) {
for( count =0; count < 10; count++) {
digitalWrite(solPin, HIGH);
delay(100); // to make the solenoid be heard
digitalWrite(solPin, LOW);
delay(timing_rythm[count +1] - timing_rythm[count] - 100)
play =0;
sketch_aug14a:9: error: array must be initialized with a brace-enclosed initializer
sketch_aug14a.cpp: In function 'void loop()':
sketch_aug14a:44: error: expected `;' before '}' token
thats better thanks AWOL its compiled fine now, but it still only getting output at the same time the piezo is triggered, not recorded then playback???
/*piezo sketch
const int THRESHOLD = 40;
long timing_rythm[10]; // 10 beat, could be more;
int count = 0;
int play = 0;
if ( !play ) {
count++;
if (play) {
delay(timing_rythm[count +1] - timing_rythm[count] - 100);
play =0;
so at the minute its triggering output as its hit, so still need it to record a succession of knocks, wait for any more and if no knocks follow for 5 seconds it then outputs the sequence.
it also seems to go to sleep or something if it hasn't been triggered for a couple of minutes so has to be reset??
As AWOL advised you, insert "printing line" in the code, so you would get information what going on and correct some code pieces, if it's not working as you expected.
First, insert in the setup:
Serial.begin(115200); // <<<<<<<--------- Serial, speed 115200 you have to select this value //in Serial Monitor window.
Than, insert "printing lines" :
if ( !play ) {
Serial.print("\t Have analog read with value: ");
Serial.println(val);
count++;
Serial.print("Number of beat: ");
Serial.println(count);
if (play) {
Serial.println("Turn to play mode, 5 sec no knocking!: ");
// Serial.println(nbr);
Serial.print("Have you heard it? , I just play beat number: ");
play =0;
So, if you like to check workflow of the program, insert as many printing lines, as necessary !
