I have been wondering if I there is any way I can store the current time in an array. Im using ds1307 rtc module.
Im trying to do a code which required the user to input and set a date using keypad (the data will be store in an array) for the arduino to unlock a door. If the date today is not equal to the set date, the door will not be unlock. Im planning to do a comparison of the current date to the set date which is store in array so when the date is equal the door will unlock.
Is there a way to store the current date in an array? If not please share another way how achieve the goal.
Is there any link or website I can refer to? Please give examples on how to store current date in an array.
What kind of array? What representation of the current time?
What kind of array is the user-entered data being stored in?
The DS1307 has 7 registers with date & time info.
Address 0: tens of seconds, units of seconds
Address 1: tens of minutes, units of minutes
Address 2: tens of hours, units of hours
Address 3: Day of week, 01 to 07
Address 4: tens of day of month, units of day of month
Address 5: tens of month, units of month
Address 6: tens of year, units of year
So simplest is to read addresses 4,5,6, convert into whole numbers and store as 3 bytes,
total days, total month, total year.
Ranges will be days 1-31, month 1-12, and year 0 to 99.
A struct is a better container for time than an array. There is one already defined for you in the Time library. You can use it or study it.
qistie:
an easy way would be to store a UNIX timestamp (unsigned long).
Call a function that calculates it for midnight
time_t today = makeTimestamp(year(), month(), day(), 0, 0, 0);
with a function that makes the timestamp like this example:
time_t DailyTimer::tmConvert_t(int YYYY, byte MM, byte DD, byte hh, byte mm, byte ss)
tmElements_t tmSet;
tmSet.Year = YYYY - 1970;
tmSet.Month = MM;
tmSet.Day = DD;
tmSet.Hour = hh;
tmSet.Minute = mm;
tmSet.Second = ss;
return makeTime(tmSet);
