Store some output values from a sensor o an array
I am developing a rain sensor. My sensing device is a piezo plate. the readings from the sensor is displaying in a 16*2 LCD display. For now I have developed my code to this level. I want to store my sensor out put values to an array using five elements . In 10s time interval. please help me this is my first industrial based project
#include <TimerOne.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 7, 9);
int inPin = 2;
int inPinCounter = 0;
void setup () {
lcd.begin(16, 2);
attachInterrupt(digitalPinToInterrupt (inPin), countFallingPluse, FALLING);
void countFallingPluse()
inPinCounter++;
inPinCounter = 0;
lcd.print("Counter Reset");
delay(10000);
lcd.clear();
if
(inPinCounter>10 && inPinCounter<50) {
lcd.print("Low Rain");
delay(10000);
lcd.clear();
else if
(inPinCounter>50 && inPinCounter<100) {
lcd.print("Mid Rain");
delay(10000);
lcd.clear();
else if
(inPinCounter > 100) {
lcd.print("High Rain");
delay(10000);
lcd.clear();
else {
lcd.print("No Rain");
lcd.setCursor(0, 1);
lcd.print("Counts:");
lcd.print(inPinCounter);
lcd.clear();
}`#include <TimerOne.h>
int inPin = 2;
void setup () {
lcd.begin(16, 2);
inPinCounter++;
inPinCounter = 0;
delay(10000);
lcd.clear();
if
delay(10000);
lcd.clear();
else if
delay(10000);
lcd.clear();
else if
delay(10000);
lcd.clear();
else {
lcd.clear();
Hello dhananjaya_l_bandara
Post your sketch, well formated, with comments and in so called code tags "</>" and a none-Fritzing schematic to see how we can help.
Have a nice day and enjoy programming in C++ and learning.
volatile
Although you display the message "Counter Reset", you don't ever reset the counter.
'delay()' is not a good way to do timing. See the "BlinkWithoutDelay" example for a way to do something periodically without using delay().
Your 'inPinCounter' variable should be marked 'volatile' and you should disable interrupts while reading or writing it in loop:
  static unsigned long timer = 0;
  if (millis() - timer >= 10000)
    timer += 10000;  // Repeat
    noInterrupts();
    int localCount = inPinCounter;
    inPinCounter = 0; // Prepare for next interval
    interrupts();
    lcd.clear();
    if (localCount < 10)
    else if (localCount < 50)
    else if (localCount < 100)
    lcd.print(localCount);
Sir can you help me to store my sensor values to the array
int inPin = 2;
void setup () {
lcd.begin(16, 2);
inPinCounter++;
inPinCounter = 0;
delay(10000);
lcd.clear();
if
delay(10000);
lcd.clear();
else if
delay(10000);
lcd.clear();
else if
delay(10000);
lcd.clear();
else {
lcd.clear();
