Store the first variable over time
Hello friends, I'm doing a SCARA arm project, just that I have a problem. When I try to automate it, the degrees I get are added as if I did not respect the point of origin.
for this reason I want to take the difference of angles so that the trajectory does not result in other coordinates
int retardo = 5;
int dato_rx;
int dato_rx2;
int numero_pasos = 0;
double valor=0;
double Q1g,Q2g;
double Pi = 3.14159;
  pinMode(11, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(4, OUTPUT);
double radianesAGrados(double radianes)
  return radianes * 180.0 / Pi;
  //double x_c = 24;
  //double y_c = 0;
  //   Radio de la figura
  //double r = 0.5;
  //Ecuacion de la figura para su trazo en coordenadas X Y Z
  //double x = x_c + r * sin(millis());
  //double y = y_c + r * cos(millis());
  double x = 24;
  double y = 0;
  double d1 = 0;
  double l2 = 14.33;
  double l3 = 12.2;
  double c2 = ((pow(x, 2)) + (pow(y, 2)) - (pow(l2, 2)) - (pow(l3, 2))) / (2 * l2 * l3);
  double Q2 = atan2(-sqrt(1 - (pow(c2, 2))), c2);
  double Q1 = (atan2(y, x)) - atan2(l3 * sin(Q2), l2 + l3 * cos(Q2));
  Q1g = radianesAGrados(Q1);
  Q2g = radianesAGrados(Q2);
dato_rx = Q1g;
    delay(retardo);
      Serial.print(dato_rx);
     // Serial.print(" Grados Q1    ");
  delay(retardo);
  dato_rx = (dato_rx * 0.477777);
  dato_rx2 = Q2g;
  //Serial.print(dato_rx2);
  //Serial.println(" Grados Q2");
  dato_rx2 = (dato_rx2 * 0.16444);
  delay(retardo);
  while (dato_rx > numero_pasos) {
    paso_izq();
    numero_pasos = numero_pasos + 1;
  while (dato_rx < numero_pasos) {
    paso_der();
    numero_pasos = numero_pasos - 1;
  apagado();
  while (dato_rx2 > numero_pasos) {
    paso_izq2();
  while (dato_rx2 < numero_pasos) {
    paso_der2();
  apagado2();
void paso_der() {
  digitalWrite(11, LOW);
  digitalWrite(10, LOW);
  digitalWrite(9, HIGH);
  digitalWrite(8, HIGH);
  delay(retardo);
  digitalWrite(10, HIGH);
  digitalWrite(8, LOW);
  delay(retardo);
  digitalWrite(11, HIGH);
  digitalWrite(9, LOW);
  delay(retardo);
  delay(retardo);
void paso_izq() {
  delay(retardo);
  delay(retardo);
  delay(retardo);
  delay(retardo);
void apagado() {
void paso_izq2() {
  digitalWrite(7, LOW);
  digitalWrite(6, LOW);
  digitalWrite(5, HIGH);
  digitalWrite(4, HIGH);
  delay(retardo);
  digitalWrite(6, HIGH);
  digitalWrite(4, LOW);
  delay(retardo);
  digitalWrite(7, HIGH);
  digitalWrite(5, LOW);
  delay(retardo);
  delay(retardo);
void paso_der2() {
  delay(retardo);
  delay(retardo);
  delay(retardo);
  delay(retardo);
void apagado2() {
I'm controlling it with 2 steppers.
Please omit the comments.
Hola,
Para recibe una repuesta en espanol, reccomiendo que ud. pregunte en el foro espanol.
https://forum.arduino.cc/index.php?board=32.0
