store values from Serial monitor to a variable
How would I store data from the serial monitor into a variable?
I would probably use something like this:
Serial.read(); int a=Serial.read();
if (Serial.read == distance is 1) { Serial.println(a);
Note: Im a complete noob
I think there is an example of this built into the Arduino program.
-jim lee
Yup, that’s pretty nooby code. You might find this helpful:
Serial input basics
@OP
We need to review few basics of UART Serial Communication, and these are:
1. When we send A (for example) from the Serial Monitor, the ASCII code 0x41 (lower bit is transmitted first under 10-bit wide UART Frame) is transmitted to the ATmega328P MCU of UNO Board.
2. When the above frame enters into the Receiver Section of the MCU, the 8-bit ASCII code is extracted from the frame (after error checking if enabled); at the same time, an 8-bit Status Code is generated; these 2-byte data (lower byte is the ASCII Code) is automatically saved in an unseen int-type buffer/array.
3. By executing the Serial.read() command, we read the 8-bit ASCII code (the lower 8-bit of the 16-bit wide member) of the buffer and save into a byte oriented variable for further processing.
4. The Serial.available() command allows us to check if a data byte has already been saved into the buffer/array.
5. Example Sketch
  if (Serial.available() > 0) //at least one data item is in the buffer/array
    byte x = Serial.read(); //read 8-bit ASCII code of character from the 16-bit item of buffer
    Serial.println((char)x); //show the character on Serial Monitor
