store when the button is pressed
hello , i need to register the time each button (there are 2 buttons ) has pressed to compare the difference ,
the time of the press of button1 - the time of the pree of button2
or vise versa should be less than 50ms to light up a redled
here what i tried to code but its not working fine , please help!
int button =3;
int button2 =4;
int redled =5;
void setup () {
pinMode(button,INPUT);
pinMode(button2,INPUT);
pinMode(redled,OUTPUT);
void loop () {
unsigned long firstpress;
unsigned long secondpress;
if (digitalRead(button)==HIGH) {
firstpress = millis();
if (digitalRead(button2)==HIGH) {
secondpress = millis();
if (firstpress - secondpress <= 50) {
digitalWrite(redled,HIGH);
delay(2000);
firstpress = digitalRead(button);
secondpress = digitalRead(button2);
this
should be
if (secondpress - firstpress <= 50) {
no?
50ms seems awfully short though.
How many times do you suppose loop() will iterate before both switches are pressed? Does creating a new variable on each pass make sense? To me, it does not.
Make the times static or global so that doesn't happen.
so this should work ?
int button =3;
int button2 =4;
int redled =5;
void setup () {
void loop () {
if (secondpress-firstpress <= 50) {
delay(2000);
hossamsh:
int button =3;
int button2 =4;
int redled =5;
void setup () {
void loop () {
delay(2000);
try it and tell us what happens
No. You want to record when the switch BECOMES pressed, not when the switch IS pressed.
I'm getting really tired of telling people to look at the state change detection example.
No, there's a fundamental problem here - you are not detecting when the button is pressed.
The button is pressed at the point where it now reads HIGH but last time it read LOW - you have
to save the state of the last time you called digitalRead() and compare against the new reading.
Have a look at StateChangeDetection example (I think that's the name) in the Arduino examples.
Well, it would still work even though he is level sensing instead of edge-sensing. He has 2 buttons.
It just wouldn't work exactly the way it should.
