Storing 2 port incoming data at a atime in SD casd
hi, I have worked on two individula prototype projects
My Intension is intigrating these 2 individuals as a one prototype
HARD WARE IS READY but GOT STUCK AT CODING
  1. Voice samples recording using microphone
HARDWARE : Arduino Mega2560, Condenser microphone circuite connected to analog port A5 with two button interups connected to D6 (start Rec) D5 (stop Rec) & microSD card (50-MISO,51-MOSI,52-CLK,53-CS)
CODE: Attachment-1
  1. Step counting using pedometer with time stamps
HARDWARE: DSPXO1 3D accelerometer sensor connected to alaog port A4 and RTC DS3231 & microSDcard module (50-MISO,51-MOSI,52-CLK,53-CS)
CODE: attachment-2
IS IT Possible ?
Two incoming analog data loding at a time using multiplexing in one micro SD card ?
APC_Digital_recordnv6.1.ino (8.04 KB)
wrking_BTL.ino (1.21 KB)
IS IT Possible ? Two incoming analog data loding at a time using multiplexing in one micro SD card ?
In the same file? Or in different files? The answer is yes, in either case, though the amount of memory needed is not.
I have different file formates microphone is .wav formate and pedo has .csv formate I want them seperate files and wanted to create in one microSD card shield
I will explain
the device is going to wear on a wrist
SO WHEN I NEED TO RECORD THE VOICE SAMPLES I HAVE TO STAND BY AND DO IT RECORDING
OBVIOUSLY NO STEPS TAKING THAT TIME
1st prototype microphone : when i press the start button code will create a dump .wave file in sd card to load the incoming A5 port data then stop button updates the file size and closes it
So, what is the problem?
I have tried in this way but it didnt work
if(((digitalRead(btnStart)==HIGH && recPressed == 0)) || ((digitalRead(btnStop) == LOW && recPressed == 1))){ // Wen the recoding button id not pressed strat counting steps
voice files doesnt have recorded voices n pedometer no data ( first checking at serial port then log the data to files later)
Final_PrgrmV1.ino (11.1 KB)
#define FIVEMIN (1000UL * 60 * 1) // Every 1 min start logging data
I suggest you make that:
#define IDONTKNOWHATIMDOING (1000UL * 60 * 1) // Every 1 min start logging data
const unsigned int darBufSize = 512;
byte buf00[darBufSize]; // buffer array 1
byte buf01[darBufSize]; // buffer array 2
byte buf02[darBufSize]; // buffer array 3
byte buf03[darBufSize]; // buffer array 4
byte buf04[darBufSize]; // buffer array 4
byte buf05[darBufSize]; // buffer array 4
byte buf06[darBufSize]; // buffer array 4
byte buf07[darBufSize]; // buffer array 4
Stupid comments aside, that's using a lot of memory.
I tried to read the rest of your code, but it wanders all over the place, like a drunken sailor.
I got a headache, so I quit. There is NO excuse for that, given how little time it takes to use Tools + Auto Format.
You open logfile, but never actually write anything to it (except the header) and you never close it.
i KNEW WHAT I AM DOING
512 buffersa are used for not lossing samplesd values of voices when the buffer used to flush samples in microSD card (preventing loss of samples 43 microsec)
I have commented on files IO opreations ( bcz filename.flush() & filename.println() not supporting in SdFAt lib) i knew i thought of replacing with proper sintaxes later ( but i used serial monitor to see steps counting ! when the button are not pressed)
I though that you can understand the logical error and guide me
