Storing a pointer to a function?
Well, I don't know if this is possible, but I need to create an Array of pointers, those pointers need to be some functions that are outside the class, and I need to call those functions inside the class .
class::NClass
    virtual void AssignFunction(byte A,void (*B)()) {FN[A] = (*B);}
    void *FN[16];
void CallFunction(byte n) {
   (*FN[n])();
this is what I came with, But I don't really have idea.
That is possible.
class::NClass
What is this? It isn't a constructor, since the method name doesn't match the class name. Therefore, it MUST have a return type.
    void *FN[16];
Local variables in the constructor are pretty useless.
Why is this prototype in the implementation file? You certainly can't assign anything to FN before you declare FN.
They contain the same thing.
You have an implementation file. Implement this function THERE.
The parentheses around the *B are not needed. The * is wrong. B is a pointer to a function. FN[A] expects to be assigned a pointer to a function.
Pulsadores::Pulsadores(byte NB, int *PinArray)
    int i = -1;
    _NB = NB;
    _PA = PinArray;
    _DT = 25000;
    for(i=-1;i<_NB;i++){
        pinMode(*(_PA+i),INPUT_PULLUP);
Do NOT diddle with the hardware (pinMode() does that) in the constructor. The hardware is not ready to be diddled with.
What is wrong, in the appropriate method, with:
   pinMode(_PA[i], INPUT_PULLUP);
Where do you actually try to use the values in FN? Where do you actually call AssignFunction()?
What do I need to de to call those functions from the Pulsadores.cpp File?
You would need to call AssignFunction() to assign a pointer to a function to FN[A], where you define what A is when calling AssignFunction().
Then, in some method in the Pulsadores class, you simply call the appropriate function. To call the ith function:
     FN[i]();
