Storing an Int Array on Micro SD Card.
Hey Team!
I’m currently working on an interactive installation, and basically I need to store an array of int’s on an SD Card, just in case the Arduino crashes.
The int’s of the array will either be of value 0, 1, 2 or 3.
It needs to be able to read/write the array from the SD Card.
Does anyone know of any examples that do this, or could point me in the right direction? It would be much appreciated :slight_smile:
-Dylan
There is a library EEPROMWriteAnything that uses templates to break up any type of data into individual bytes, so you can write it, and read back from, EEPROM.
http://arduino.cc/playground/Code/EEPROMWriteAnything
You could use the technique (modified a bit) to write to, and read back from, the SD card.
The int's of the array will either be of value 0, 1, 2 or 3.
So, the ints will all be byte sized. Tell us, again, why they need to be ints.
