Storing Array of Strings in Program Memory
So I want to conserve RAM by storing my array of Strings for my LCD in the flash memory of my arduino ATMega328P. I am using v. 1.6.7 of the IDE. When I upload this code without the array it runs correctly, however with the array it compiles and uploads but the LCD is blank...
#include <Wire.h>
//#include <avr/progspace.h>
#define num_saved_wands 5
#define I2C_ADDR    0x27
#define BACKLIGHT_PIN     3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
LiquidCrystal_I2C  lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
  lcd.begin (16,2);
  lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.home();
  lcd.print(F(" Welcome to the"));
  lcd.setCursor (0,1);
  lcd.print(F(" LCD"));
  delay(2000);
  lcd.clear();
}//end setup
PROGMEM const String Menu[9][4] = {
  {"Adjs","Imgs","Text","Functions"},   //1
  {"1-Wand","2-Bands","Rainbow", ""},//2   //Adjust
  {"1-Saved","2-Create","3-Main",""},  //3   //Adjust --> Wand
  {"1-Saved","2-Create","3-Main",""},  //4   //Adjust --> Bands
  {"Main","","",""},                           //5   //Adjust --> Rainbow
  {"Run","Main","",""},                      //6   //Imgs
  {"1-Saved","2-Create","3-Main",""},  //7   //Text
  {"Run","Main","",""},                      //8   //Text Run
  {"Main","","",""}                            //9   //Functions
}//end loop
Thanks.
See the example at nongnu.org for PROGMEM which shows how to use PROGMEM for arrays of strings. (Google)
Mark
holmes4:
Mark
Not that strings and Strings are NOT the same thing. One can store strings in PROGMEM. One can NOT store Strings in PROGMEM.
