You have entered the following string from the InputBox of the Serial Monitor; where, '<' is the "Start Mark" and '>' is the "End Mark". There are three symbols like this: '>'; so, which one is the "End Mark"?
<123>(456>[789>
Please correct your string, limit your array dimensions to (say 20) reasonable values as @Coding Badly has suggested, and state your requirements:
Do you want to save 123 into this array: char receivedcharsA[20];?
Do you want to save 456 into this array: char receivedcharsB[20];?
Do you want to save 789 into this array: char receivedcharsC[20];?
If you like, you can use "comma separated" style for your data items like the following:
<123,456,789>
are you saying that you possibly have 3 start markers and depending on which one is used (<, ( or [), the value is for A, B or C? sending A123> or B456> or C789> would probably be easier to remember / read
are you in charge of defining that protocol? are you always sending the 3 values? if so, as @golamMostafa suggests, <123,456,789> would probably be easier to parse.
And if you end with '\n' then you probably don't need the start and end markers - just read a line 123,456,789 (drop the '\n') and extract the data separated by the commas.
If you follow what @J-M-L has said in his Post-4 (sending comma separated string/data items with '\n' (the Newline character) as terminating character, and no "Start/End Marks"), then you may exercise the following tested codes (blocking) to extract your substrings (data items as well if the input string contains only numerals: 0 - 9) coming from the InputBox of the Serial Monitor.
Please, remember to select "Newline" option for the "Line ending tab" of Serial Monitor (Fig-1).
char myData[20];
char receivedcharsA[10];
char receivedcharsB[10];
char receivedcharsC[10];
byte y = Serial.available(); //chacke that a data item is in Serial Buffer
if (y != 0) //there is at least one data item in Serial Buffer
byte m = Serial.readBytesUntil('\n', myData, 20); //save until and without Newline ('\n')
myData[m] = '\0'; //always insert null-charcater as last element fo char type array
Serial.println(myData); //shows: 123,456,789
byte i = 0;
byte j = 0;
do
receivedcharsA[j] = myData[i]; //copy the charcaters for substring 123
i++;
j++;
while (myData[i] != ',');
receivedcharsA[j] = '\0';
//int data1 = atoi(receivedcharsA); //data1 holds 123 (= 0x7B)
//Serial.println(data1, DEC);
Serial.println(receivedcharsA);
j = 0;
i++;
do
receivedcharsB[j] = myData[i]; //copy the charcaters for substring 456
j++;
i++;
receivedcharsB[j] = '\0';
Serial.println(receivedcharsB);
j = 0;
i++;
do
receivedcharsC[j] = myData[i]; //copy the charcaters for substring 789
j++;
i++;
while (myData[i] != '\0');
receivedcharsC[j] = '\0';
Serial.println(receivedcharsC);
Serial.println("===========================");
depending on which one of three start markers, '<', '(', '[', he copies chars into on of the three arrays until the stop marker, '>', is detected. but there are 3 different flags indicating which array is being used but the code always clears the same flag, recInProgress.
