Not-A-Bot:
This is all of my code pertaining to the camera, I am using a status holder to store most of my values but you should be able to follow along.
String takePic(int ImageSize) {
// Try to locate the camera
if (!camStatus) {
Serial.println(“Camera Fail”);
return “”;
//cam.begin(); //Need to ensure it worked
cam.setImageSize(ImageSize);//cam.setImageSize(VC0706_160x120);
if (!cam.takePicture()) {
Serial.println(“Take Failure”);
return “”;
StatusHolder.numPhotos++;
Serial.print("Picture taken! ");
// Create an image with the name Axxxx.JPG //ALTER THIS TO STORE THE NEXT AVAILABLE FILENAME
char filename[9];
strcpy(filename, “A0000.JPG”);
for (int i = 0; i < 9999; i++) {
filename[1] = ‘0’ + i / 1000;
filename[2] = ‘0’ + i % 1000 / 100;
filename[3] = ‘0’ + i % 1000 % 100 / 10;
filename[4] = ‘0’ + i % 1000 % 100 % 10;
if (!SD.exists(filename)) {
Serial.print("File created: ");
Serial.println(filename);
File imgFile = SD.open(filename, FILE_WRITE); //Open Image File
uint16_t jpglen = cam.frameLength(); //Image Size in Bytes
uint16_t bytesWritten = 0;
//int32_t time = millis();
pinMode(8, OUTPUT);
// Read all the data up to # bytes!
byte wCount = 0; // For counting # of writes
long startT = millis();
while (jpglen > 0 && 1) { //(millis() - startT <= 3000)) {
uint8_t *databuffer;
uint8_t bytesToRead = min(64, jpglen); // 64 Byte Reads
databuffer = cam.readPicture(bytesToRead);
bytesWritten += imgFile.write(databuffer, bytesToRead); //Returns bytes written if needed
if (++wCount >= 64) { // Every 2K, give a little feedback so it doesn’t appear locked up
//Reset Timer Here
wCount = 0;
jpglen -= bytesToRead;
//Serial.println(jpglen);
Serial.print(“capture time:”);
Serial.println(millis()-startT);
// if (millis() - startT <= 3000) {
// Serial.println(“Photo Write Timeout”);
imgFile.close();
//time = millis() - time;
camStatus = false;
return filename;
when using ‘cstrings’ remember to include space for the trailing NULL:
char filename[9];
strcpy(filename, "A0000.JPG");
Needs to be at least:
char filename[10];
Where is databuffer pointing? is it pointing to a memory buffer internal to the cam() object?
if (++wCount >= 64) { // Every 2K, give a little feedback so it doesn't appear locked up
//Reset Timer Here
wCount = 0;
Is uint8_t* cam.readPicture(uint8_t bufsize); actually:
uint8_t* cam.readPictureNextBytes(uint8_t bufsize);?
Does the cam() object maintain a ‘current’ position for the ‘read’ function?
Chuck.
