Storing Min and Max Temperature
I am trying to display min and max temperature on an LCD screen using a one wire temp sensor. for some reason I am unable to set the min and max temp values and have them display. My code is attached
Temp-Sensor-LCD.ino (4.1 KB)
Edit:
I found the problem (attached if you are interested) and it was with my reset of the min max temp. oops realized it right after posting. Now only a PID loop, relay and rotary encoder and I’ll have a standalone temperature controller.
I’m sure it is very interesting, but it’s more trouble than it is worth to look at it. Please read the please reads at the head of the forums to insert code in the proper manner, using the </> tags.
Thanks good point. Here is the updated code if you are interested.
//  Include the libraries below
#include <OneWire.h>
#include <DallasTemperature.h>
#include <LiquidCrystal.h>
#include <Bounce.h>
// initialize the lcd library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
// Data wire for one wire sensors is on pin 3
#define ONE_WIRE_BUS 4
//Define encoder pins
#define encoderPinA  2
#define encoderPinB  3
Bounce rotaryA = Bounce(encoderPinA,5);
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
DeviceAddress Temp1 = { 0x28, 0xA8, 0x4B, 0x22, 0x05, 0x00, 0x00, 0x38 };
const int displaySwitch = 5;
const int displayOnOff = 6;
int onCount;
float tempSP = 33;
float maxTemp =-100;
float minTemp=100;
int resetCount = 0;
void setup(void)
  // start serial port
  // Start up the library
  sensors.begin();
  // set the resolution to 10 bit
  sensors.setResolution(Temp1, 10);
  //Setup LCD
  lcd.begin(16, 2);
  //Setup Button pins
  pinMode(displaySwitch, INPUT);
  pinMode(displayOnOff, OUTPUT);
  //setup encoder
  pinMode(encoderPinA, INPUT_PULLUP);
  digitalWrite(encoderPinA, HIGH);       // turn on pullup resistor
  pinMode(encoderPinB, INPUT_PULLUP);
  digitalWrite(encoderPinB, HIGH);       // turn on pullup resistor
  //Setup interupt
  attachInterrupt(0, doEncoder, CHANGE);  // encoder pin on interrupt 0 - pin 2
  attachInterrupt(1, doEncoder, CHANGE);  // encoder pin on interrupt 1 - pin 3
void doEncoder() {
  /* If pinA and pinB are both high or both low, it is spinning
   * forward. If they're different, it's going backward.
   * For more information on speeding up this process, see
   * [Reference/PortManipulation], specifically the PIND register.
  if (digitalRead(encoderPinA) == digitalRead(encoderPinB)) {
    tempSP = tempSP + 0.5;
    tempSP = tempSP - 0.5;
  lcd.clear();
  lcd.print("SetPoint:");
  lcd.print(tempSP,2);
  lcd.print(" F");
void printTemperature(DeviceAddress deviceAddress)
  // This is the Serial Print function to see temperature if the diplay is not working
  Serial.print("Getting temperatures...\n\r");
  sensors.requestTemperatures();
  Serial.print("Current temperature is: ");
  float tempC = sensors.getTempC(deviceAddress);
  if (tempC == -127.00) {
    Serial.print("Error getting temperature");
    Serial.print("C: ");
    Serial.print(tempC);
    Serial.print(" F: ");
    Serial.print(DallasTemperature::toFahrenheit(tempC));
    Serial.print("\n\r");
void displayTemperature(DeviceAddress deviceAddress)
	delay(2000);
float tempF = sensors.getTempF(deviceAddress);
   //calculate min and max
   if (tempF>maxTemp){maxTemp = tempF;}
   if (tempF<minTemp){minTemp = tempF;}
   if (tempC == -127.00) // Measurement failed or no device found
    lcd.clear();
    lcd.print("Temperature Error");
   lcd.clear();
   lcd.print("SetPoint=");
   lcd.print(tempSP,2); //Display Setpoint
   lcd.print(" F");
   lcd.setCursor(0,1);  //Start at character 0 on line 1
   lcd.print("Act.Temp=");
   lcd.print(tempF,2); //Display temperature reading with 2 decimal places
   lcd.print(" F");
   tempF = 0;
void displayMinMaxTemperature(DeviceAddress deviceAddress)
   delay(2000);
   lcd.clear();
   lcd.print("Min Temp=");
   lcd.print(minTemp,2); //Display min temp
   lcd.print(" F");
   lcd.print("Max Temp=");
   lcd.print(maxTemp,2); //Display max temp
   lcd.print(" F");
void backLightReset()
  //Now turn on the backlight if the button is pressesd
  //Now rest min and max temps if button is held down
  if (digitalRead(displaySwitch) == HIGH){
   onCount = 5; // This determines time that it will stay on
  // Remember delay also affects the time it is on
   resetCount = resetCount + 1;}
  else{
  	resetCount = 0;
   if(onCount > 0){
    onCount = onCount - 1;
   else{
    onCount = 0;
  if(onCount > 0){
   digitalWrite(displayOnOff, HIGH);
  else{
   digitalWrite(displayOnOff, LOW);
  if(resetCount > 3){
   maxTemp = -100;
   minTemp = 100;
void loop(void)
  // Thiw will print the temp reading so it can be read
  // through serial connection when a display is not attached
  // Remove this to speed things up once the display is working
  //printTemperature(Temp1);
  // This will display temp and setpoint on the LCD
  displayTemperature(Temp1);
  // Now turn on the backlight if the button is pressesd
  // Now rest min and max temps if button is held down
  backLightReset();
  // Display Min and Max Temperatures
  displayMinMaxTemperature(Temp1);
  backLightReset();
