I am trying to enter in and store three values from the LCD Keypad shield, unsuccessfully. This is my fist arduino program but I have basic experience with C.
What I want to do: I’m making a dip-coater that will lower something very slowly over a specified distance and then return at a different rate. I have the motor shield set up and ready. it just needs the downward speed, the distance, and upward speed input from the keypad.
What I’m working with: DIYMall 1602 lcd keypad shield, arduino uno.
What I need help with: I have been able to successfully enter and save one value through the keypad but when i try and duplicate it for three values I am running into all sorts of problems. No actual errors, only problems. I need help figuring out where I should be placing each call to a function and how to get each call to save the given variable. As is, I try to get the three variables from the keypad in the setup stage so that in the loop I can just let the motor run at the given speeds and distance. It seems to just skip over the function to get inputs from the keypad. It will show “enter speed”, “enter distance”, and “enter reverse” but will not go into the function to allow the user to enter and store a variable. A lot of the keypad code I used from a layout my friend made for a similar program with only one input required.
Any help or suggestions are appreciated, thanks.
#include <LiquidCrystal.h>
LiquidCrystal lcd(8,9,4,5,6,7);
enum {btnNONE, btnSELECT, btnLEFT, btnUP, btnDOWN, btnRIGHT, NUM_KEYS };
const byte ButtonsPin= A0;
char value[]= "000";
int cursorPos = 0;
boolean lcdNeedsUpdate=true;
double MotorSpeed = 0;
double Depth = 0;
double Reverse = 0;
int x = 0;
int a = 0;
lcd.begin(16,2);
lcd.clear();
lcd.print("Dip Coater");
lcd.clear();
lcd.setCursor(0,0);
while (a == 0)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Enter Speed: ");
lcd.blink();
double Input1(double Motorspeed);
Serial.println(MotorSpeed);
a = a++;
while (a > 0 || a < 2)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Enter Depth: ");
lcd.blink();
double Input2(double Depth);
Input2(Depth);
Serial.println(Depth);
a = a++;
while (a > 1 || a < 3)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Reverse Speed: ");
lcd.blink();
double Input3(double Reverse);
Input3(Reverse);
Serial.println(Reverse);
a = a++;
// This would be the code for telling the motor to go down at Motorspeed, for depth of Depth, and return at Return speed.
// myMotor->setSpeed(MotorSpeed);
// myMotor->step(MotorSpeed, FORWARD, INTERLEAVE);
int read_LCD_buttons()
int returnValue;
// read ADC value of pressed button
int adc_key_in = analogRead (ButtonsPin);
int adc_key_in1= analogRead (ButtonsPin);
// read again and check for stable ADC reading (software debouncing for analog input)
if (abs(adc_key_in1-adc_key_in)>3) return btnNONE; // if ADC reading is not stable, return btnNONE
if (adc_key_in <50) returnValue= btnRIGHT;
else if (adc_key_in <150) returnValue= btnUP;
else if (adc_key_in <325) returnValue= btnDOWN;
else if (adc_key_in <500) returnValue= btnLEFT;
else if (adc_key_in <800) returnValue= btnSELECT;
else returnValue=btnNONE;
// simple "blocking" code: "Busy waiting" until button is released by user
while(adc_key_in<800) adc_key_in= analogRead(ButtonsPin);
return returnValue;
//function to read input from the screen and return a plunge speed
char key=read_LCD_buttons();
if (key!= btnNONE) lcdNeedsUpdate=true;
switch (key)
case btnRIGHT:
if (cursorPos<2) cursorPos++;
case btnLEFT:
if (cursorPos>0) cursorPos--;
case btnUP:
if (value[cursorPos]<'9') value[cursorPos]++;
case btnDOWN:
if (value[cursorPos]>'0') value[cursorPos]--;
case btnSELECT:
lcd.print("Saved value: ");
//Serial.println(value);
cursorPos=0;
lcd.clear();
lcd.setCursor(0,1);
lcd.print (value);
MotorSpeed = atoi(value); // converts "value" into a double to be used as RPM speed
if (lcdNeedsUpdate) //continually refreshes the display as numbers are changed up and down
lcd.setCursor(0,1);
lcd.print(value);
lcd.setCursor(cursorPos,1);
lcdNeedsUpdate=false;
return MotorSpeed;
// function for depth input from keypad
switch (key)
case btnRIGHT:
case btnLEFT:
case btnUP:
case btnDOWN:
case btnSELECT:
cursorPos=0;
lcd.clear();
lcd.setCursor(0,1);
lcd.print (value);
Depth = atoi(value); // converts "value" into a double to be used as RPM speed
lcd.setCursor(0,1);
lcd.print(value);
return Depth;
//function for return speed from keypad
double Input3 (double Reverse)
switch (key)
case btnRIGHT:
case btnLEFT:
case btnUP:
case btnDOWN:
case btnSELECT:
cursorPos=0;
lcd.clear();
lcd.setCursor(0,1);
lcd.print (value);
Reverse = atoi(value); // converts "value" into a double to be used as RPM speed
lcd.setCursor(0,1);
lcd.print(value);
return Reverse;
