system
October 5, 2014, 11:13am
#1
Hi, I've only started working on working with Arduino and I have been wondering if it is possible to change a string with multiple variables to intergers. I'm trying to control the colors of a Neopixel strip and instead of creating multiple arrays for each of the RGB, I would like to have it in their sets. Is that possible? Below is what I want to do. I do understand that the code below returns with an error.
String colors[] = {"255,0,0"};
chase(strip.Color(colors[0])); // Red
you need to split the String in parts - the numbers are separated by comma's
every separate part can be converted to int by themselves.
system
October 5, 2014, 12:39pm
#3
robtillaart:
In which case, storing the data as Strings that you need to convert to string to convert to ints makes NO sense.
KenF
October 5, 2014, 12:56pm
#5
Why not just use an integer array in the first place
eg
int colours[]={255,0,0};
or you could even save several predefined colours such as
int colours[][3]={255,0,0, //red
0,255,0, //green
0,0,255, //blue
255,255,0, //yellow
128,128,128//grey
Then to find the RGB values for your chosen colour you'd use
red=colours[selectedColour][0];
green=colours[selectedColour][1];
blue=colours[selectedColour][2];
system
October 5, 2014, 6:27pm
#7
KenF:
eg
0,255,0, //green
0,0,255, //blue
255,255,0, //yellow
128,128,128//grey
I've already considered this one, but I was thinking if there was any shorter way of doing it. I guess not.
Thanks for the reply.
Appreciate the help.
KenF
October 5, 2014, 6:59pm
#8
There is but it gets slightly less readable. You could describe the array as follows
unsigned long colours[]={16711680ul, //red
65280ul, //green
255ul, //blue
16776960ul,//yellow
8421504,//grey
103745 //a bit like digestive biscuit
Then to get all of the RGB factors into a byte array, you simply use
byte *rgb=(byte *)&colours[selectedColor];
//rgb[1] now has red factor
//rgb[2] now has green factor
//rgb[3] now has blue factor
maybe hexadecimal notation?
0x00FF0000
0x0000FF00
system
October 5, 2014, 7:08pm
#10
unfortunately I'm still green in the coding language so I can mostly do colors only through the basic method. Hexadecimal or any other is very alien to me, but I would love to learn it to simplify it.
an example to explain. (otherwise google is your friend.
255, 0, 0 => 255256 256 + 0 * 256 + 0 = 16711680uL == 0x00FF0000
0x00FF0000 == 00 FF 00 00 == 00 255 00 00
