Intension :
I am trying to push the parsed data from the GPS into the Server database. I have given the code below :
Board and shields used :
- Arduino Uno
- Arduino GSM shield
- Adafruit Ultimate GPS Logger Shield
Work done Bofore:
- As the GPS shield overlaps with GSM shield, I cut the trace and connected to Pin 7 and connectected Rx with Pin9.
- I removed the SoftwareSerial Library and replaced with AltSoftSerial library.
If I connect to the server, its not woking else working perectly...
This is the complete code :
The result I get is: Garbage values
My serial monitor baud rate is in 115200
ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ ) ÿ )
I have more memory
Binary sketch size: 25,342 bytes (of a 32,256 byte maximum)
Is there any problem in my server connection ? I don't think so, becouse It works for my other projects. Where is the problem ?
Thank you.
