Hello everyone!
Long time watcher, first time poster. Hopefully I can articulate my problem well, feel free to give me pointers on posting here.
I am working on a project built on the ESP32-S3 board, using the latest version of the Arduino core for ESP32 (v3.0.0-alpha3). This project is an MP3 player with a file browser UI. File in question attached below. The entire project is quite large and most of it is not relevant to this question, I can attach full source if needed. This is very much still WIP and I am aware that there are parts of this UI implementation that need review. I am just focused on this file reference problem right now.
#ifndef UI_H
#define UI_H
#include <Adafruit_GFX.h>
#include <Fonts/TomThumb.h>
#include "display.h"
#include "player.h"
#include "buttons.h"
#include "button_functions.h"
#include "src/track_tags/tags.h"
const int MAX_DISPLAY_ITEMS = 12;
const int MAX_DISPLAY_INDEX = MAX_DISPLAY_ITEMS - 1;
const int MAX_BROWSER_ITEMS = 1024;
const int FILE_TYPE_MUSIC = 0;
const int FILE_TYPE_DIRECTORY 1;
const int FILE_TYPE_PLAYLIST 2;
struct UiFileEntry{
char path[256];
char name[128];
uint8_t type;
class UI {
public:
Adafruit_SSD1327* display;
Player* player;
Buttons* buttons;
char cwd[128] = "Initializing...";
bool pendingUpdate = false;
UI(Adafruit_SSD1327* _display, Player* _player, Buttons* _buttons) {
display = _display;
player = _player;
buttons = _buttons;
bool init(){
// Allocate strings for UI display in PSRAM
for (int i=0; i < MAX_BROWSER_ITEMS; i++){
browserList[i] = (UiFileEntry *)ps_malloc(sizeof(UiFileEntry));
display->setRotation(3);
display->setTextWrap(false);
enterDirectory("/");
displayStatusBar();
displayNavBar();
displayCwdBar();
displayMain();
// TODO: Playqueue should not start prepopulated, remove once dev work is far enough along
for(int i=0; i<browserLen; i++){
player->appendQueueLast(browserList[i]->path);
buttons->clickWheel.setUpFunction(UI_SCROLL_UP);
buttons->clickWheel.setDownFunction(UI_SCROLL_DOWN);
buttons->clickWheel.setShiftUpFunction(UI_PAGE_UP);
buttons->clickWheel.setShiftDownFunction(UI_PAGE_DOWN);
buttons->next.setPressFunction(UI_SCROLL_UP);
buttons->previous.setPressFunction(UI_SCROLL_DOWN);
buttons->select.setPressFunction(UI_SELECT);
buttons->play.setPressFunction(UI_PLAY_PAUSE);
buttons->option.setPressFunction(UI_DIRECTORY_UP);
return true;
void tick(){
if(pendingUpdate){
Serial.println("Updating display");
display->display();
void scroll(int items) {
selectionIndex = selectionIndex + items;
if (selectionIndex + displayStartIndex < 0) {
// Beginning of browser reached
selectionIndex = 0;
} else if (selectionIndex + displayStartIndex >= browserLen) {
// End of browser reached
selectionIndex = MAX_DISPLAY_INDEX;
} else if (selectionIndex < 0) {
displayStartIndex = max(0, selectionIndex + displayStartIndex);
selectionIndex = 0;
} else if (selectionIndex > MAX_DISPLAY_INDEX){
// Move entire display list down
displayStartIndex = min(browserLen - MAX_DISPLAY_ITEMS,
displayStartIndex + selectionIndex - MAX_DISPLAY_INDEX);
Serial.print("Cursor index: "); Serial.println(selectionIndex);
Serial.print("Browser index: "); Serial.println(getBrowserIndex());
displayMain();
void select() {
UiFileEntry *selectedItem = browserList[displayStartIndex + selectionIndex];
if (selectedItem->type == FILE_TYPE_MUSIC) {
player->appendQueueLast(selectedItem->path);
Serial.print("Appending "); Serial.println(selectedItem->name);
} else if (selectedItem->type == FILE_TYPE_DIRECTORY) {
enterDirectory(selectedItem->path);
displayMain();
displayCwdBar();
Serial.println("Selected item is not implemented yet");
void upDirectory() {
if (strcmp("/", cwd) == 0) {
// We are at the root directory, take no action
return;
char * const last = strrchr(cwd, '/');
if (last == cwd) {
// We are one away from root, do not blow away trailing /
cwd[1] = '\0';
} else if (last != NULL){
*last = '\0';
enterDirectory(cwd);
displayMain();
displayCwdBar();
private:
UiFileEntry *browserList[MAX_BROWSER_ITEMS];
int browserLen = 0;
const byte navStartY = 115;
const byte boxWidth = SCREEN_WIDTH / 4;
const byte boxHeight = SCREEN_HEIGHT - navStartY;
const byte navTextY = navStartY + 9;
const byte mainStartY = 17;
const byte cwdStartY = 9;
uint16_t displayStartIndex = 0;
int8_t selectionIndex = 0;
uint8_t rowStartYVals[MAX_DISPLAY_ITEMS] = {16, 24, 32, 40, 48, 56, 64, 72, 80, 88, 96, 104};
int getBrowserIndex() {
return displayStartIndex + selectionIndex;
void displayStatusBar() {
display->drawFastHLine(0, 7, SCREEN_WIDTH, SSD1327_WHITE);
display->drawFastHLine(0, 8, SCREEN_WIDTH, SSD1327_WHITE);
display->setFont(&TomThumb);
display->setTextColor(SSD1327_WHITE);
display->setTextSize(1);
display->setCursor(0, 5);
display->print("Whaddup");
display->setCursor(112, 5);
display->print("100%");
void displayNavBar() {
for (int i=0; i<4; i++){
display->drawRoundRect(i * boxWidth, navStartY, boxWidth, boxHeight, 4, SSD1327_WHITE);
display->setCursor(3, navTextY); display->print("Browser");
display->setCursor(38, navTextY); display->print("Queue");
display->setCursor(68, navTextY); display->print("Playing");
display->setCursor(98, navTextY); display->print("Settings");
pendingUpdate = true;
void displayCwdBar() {
display->fillRect(0, cwdStartY, 128, 7, SSD1327_WHITE);
display->setTextColor(SSD1327_BLACK);
display->setCursor(2, 14);
display->print(cwd);
void displayMain() {
display->fillRect(0, mainStartY, 128, navStartY - mainStartY, SSD1327_BLACK);
// TODO: This rectangle will eventually be the cursor
display->fillRect(0, rowStartYVals[selectionIndex], 128, 9, 2);
display->setFont();
display->setCursor(0, mainStartY);
for (int i = displayStartIndex; i < min(browserLen, MAX_DISPLAY_ITEMS) + displayStartIndex; i++){
display->println(browserList[i]->name);
void enterDirectory(char *path) {
browserLen = 0;
File dir = SD_MMC.open(path);
strcpy(cwd, path);
while(true) {
File entry = dir.openNextFile();
if (!entry) {
// We've reached the end of the directory
} else if (!strncmp(entry.name(), ".", 1)) {
// Files starting with "." are hidden, do not display
continue;
if (entry.isDirectory()) {
strcpy(browserList[browserLen]->name, entry.name());
strcpy(browserList[browserLen]->path, entry.path());
browserList[browserLen]->type = FILE_TYPE_DIRECTORY;
// TODO: Add a visual indicator that this is a directory
getTrackTitle(browserList[browserLen]->name, entry);
browserList[browserLen]->type = FILE_TYPE_MUSIC;
browserLen++;
entry.close();
dir.close();
#endif
I am currently storing an array of structs representing the contents of a single directory in RAM. I would like this in working memory to help keep the UI quick and responsive. Currently I store the filepath, a display name (track title or directory name) and a type descriptor for each file.
struct UiFileEntry{
char path[320];
char name[128];
uint8_t type;
The browser display array is currently 1024 items long, so as you can imagine this has a pretty big memory footprint. This is not giving me problems as I have 8MB of PSRAM available, but I can't help but feel like there is a more memory efficient way to store reference to a file.
I've tried storing a pointer to the File
object in my UIFileEntry
struct, as the File
object is only 24 bytes, but it is not something I can work with. I've looked at doing something like below:
File testFile = SD_MMC.open("/text.txt");
Serial.println(testFile.read());
testFile.close();
testFile.open();
testFile.close();
But the File
object has no means for reopening a file that has been closed.
I've also looked at something like this:
testFile.close();
testFile = SD_MMC.open(testFile.path());
testFile.close();
But that results in instant core dump. Given that there is a max open file limit in the SD library, I assume there is a pool of memory not contained in the FIle object that is no longer accessible once the file is closed, as it is freed up for a new open file. Correct me if I am wrong.
Based on my limited understanding of filesystems, the path an abstract that should resolve to something more concrete like a starting address in memory for the file or something. Is there something smaller than the path string that can be used to reference the file? Alternatively, is there some way to reuse the File
object once it is closed that I have passed over?
The current implementation is functional and still leaves me with 90% of my RAM, but my gut says there is a better way to implement this.
