I am using this code to send a string from arduino to PC
int i=0;
void setup(){
Serial.begin(9600); // Open serial connection at a baud rate of 9600
pinMode(13, OUTPUT); //set pin13 in o/p mode
void loop(){
while(1)
Serial.write("10.028371,76.328873");
Serial.write('\0');
I need a python code that receives this string and store it in a text file as such.The arduino is transmitting this string continuously but i need it only once in the text file. I have written the below code but am getting only unexpected values in the text file
import the serial library
import serial
Boolean variable that will represent
whether or not the arduino is connected
connected = False
establish connection to the serial port that your arduino
is connected to.
locations=['/dev/ttyUSB0','/dev/ttyUSB1','/dev/ttyUSB2','/dev/ttyUSB3']
for device in locations:
try:
print "Trying...",device
ser = serial.Serial(device, 9600)
break
except:
print "Failed to connect on",device
loop until the arduino tells us it is ready
while not connected:
serin = ser.read()
connected = True
open text file to store the current
##gps co-ordinates received from the rover
text_file = open("position4.txt", 'w')
read serial data from arduino and
write it to the text file 'position.txt'
while ser.read():
x=ser.read()
print(x)
if x=="\0":
text_file.seek(0)
text_file.truncate()
text_file.write(x)
text_file.flush()
close the serial connection and text file
text_file.close()
ser.close()
