Storing strings of various lengths - am I doin' it right? (pointers)
Absolute newbie C question. I need to store some static phrases to put on a display, but the lengths of them vary. Which of these options is the best way to store the strings?
char myPhrases[][]= {"hello","goodbye","please go away"};
// I think this would allocate 15 characters (ie length of the longest string)
// to every string whether needed or not - is that correct?
Then I tried:
char allMyPhrases[] = "hello\0goodbye\0please go away\0";
char* myPhraseOffsets[] = {0,6,14};
// This ought to be as space-efficient as possible, but it's a
// pain to change one of the first phrases as you have to
// re-count all the offsets by eye
But this seems to work, too, and kinda looks more correct as well as being more programmer friendly:
char* myPhrases[]={"hello","goodbye","please go away"};
// but I can't tell if it's padding the strings or not.
When I google “storing strings of different lengths” I end up with results that seem overly complicated, linked lists and vectors and stuff. What’s the standard C programmer’s approach to this?
(I know that as the phrases are static, I ought to put them into the PROGMEM bit of the chip, but that can come later once I’ve sussed this pointers malarkey)
Thanks, h
The last one...
Cool, thanks! :)
// This ought to be as space-efficient as possible, but it's a // pain to change one of the first phrases as you have to // re-count all the offsets by eye
If you had[b]byte[/b] myPhraseOffsets[] = {0,6,14}; you would have saved 3 bytes, compared to the "Cool" solution with 3 char* to the different strings. Costs a bit more typing in usage
Serial.prinln(allMyPhrases[myPhraseOffsets[i]]);
Real RAM saving goes with PROGMEM, though.
