Storing Tag Data from RFIDuino into Array
So my senior mechanical engineering group is converting a hobby CNC setup to play Jenga. We are identifying each block with a unique RFID tag. We have spent the past 2 days trying to debug the scanner to move across a row of blocks and store the tag identifyer in an array as it reads. The two main issues are: 1) The scanner does not read the tags which moving across the row. 2) The scanner beeps, but prints 0 values to the serial monitor. Any help is much appreciated as this is due on Saturday. We're all guaranteed A's for effort, but we'd sure as hell like to get it to work. Thanks! Heres the relative code:
digitalWrite(xAxisDir, LOW);
tone(xAxisMotor, 500, 7000);
milliSeconds = millis() + 10000; //waiting for tone to end
delay(2000); //waiting to reach tag range of 1st block
tagCheck = myrfid.decodeTag(tagData);
for (int j = 0; j < 3; j++){
if (tagCheck == true){
digitalWrite(buzzer, HIGH);
delay(100); //time for buzzer to sound
towerArray[row][j] = tagData[4];
while(millis() < milliSeconds); //do nothing while waiting for tone to finish
You want a snippet of an answer? OK. You need to...
Are you going to use millis() or delay()? Yes is the wrong answer. So it both.
Does it make any sense to loop if tagCheck is false? Does it make any sense to store the 5th part of the response in three different places?
The for loop is used to place the value of the tag in the correct block in the Jenga row. The delay is to wait for the motor to finish moving.
So? The for loop accomplishes nothing if tagCheck is false. Testing tagCheck on every iteration of the loop is silly. Check it ONCE:
  { // Down here where it belongs
So, why are you storing the same piece of information in 3 elements of the towerArray array?
Does Array REALLY need to be in the name of the variable? Don't the square brackets tell you that the variable is an array?
