storing text in EEPROM
Hi Folks,
Since a while I try desperately to store some user data for a internet server based on an ESP266 in its EEPROM.
First of all I cannot clearly seperate the input strings (see text in below). Secondly I am not able to store the input in the chip EEPROM. :o
input:
USERtest
output:
memoryNo: 2<
SSID: test<
SECR: test<
USER: test<
UPWD: test<
VAR1: ?<
VAR2: ?<
VAR3: €<
—End of data set—
Can somebody help me?
Pool_Server_serial-test.ino (4.94 KB)
Make it easy for us to provide help by posting the code here in code tags.
Hotzenplotz:
Is the code running on a standard Arduino such as Uno that is connected to an ESP8266 or is it running on the ESP8266?
EEPROM.read() and EEPROM.write() only read/write a single byte. Have a look at the EEPROM reference: Arduino - EEPROM. I think you'll find EEPROM.get() and EEPROM.put() to be useful. Remember to allocate enough EEPROM for each buffer(hint, one byte definitely won't do it).
The EEPROM of ESP8266 works a bit differently than Arduino EEPROM. https://github.com/esp8266/Arduino/blame/master/doc/libraries.md
