Storing Time and Using Remaining time Inside a Loop
My sketch is supposed to calculate the total time used for all assigned tasks and wait until a fixed amount of time has passed before proceeding to start all over again; I calculated in Microseconds how much time total was used as follows. Example Total Time: time used reading a sensor+ time a fan was on + time a door was open... The time allowed to complete all tasks is 300 milliseconds. Sometimes, some jobs don't need to be done, for whatever reason, so time is not used for that job. Most of the time I have unused time; I intended to use the time leftover inside a loop until the 300 milliseconds were up. I haven't being successful. I am going nuts at the moment; I created a billion time variables and I wonder if anyone can give me a hand. Using either microseconds and/or milliseconds is fine. I created couple variables just to see how they helped me, so any variable can be discarded if that's the case. This is my code so far. Sorry about not a clean code
pinMode(13, OUTPUT); // LED on pin 13
uint32_t lastTime  = 0L;
int lineCounter = 0;
  while (lineCounter <= 4500) {
    Serial.print(lineCounter);
    Serial.print(" ");
    uint32_t currentTime = millis(); // Current time, milliseconds
    Serial.print(currentTime = micros());
    for (i = 0; i < CHANNEL_COUNT; i++)
      //Do Something One
    for (bitNumber = 0; bitNumber < totalBits; bitNumber++) {
      //Do something Two
    for (i = 0; i < CHANNEL_COUNT; i++) {
      //Do something Three
    Serial.print(" - ");
    Serial.print(lastTime);
    Serial.print(" = ");
    Serial.print((currentTime - lastTime));
    uint32_t timeUsed = currentTime - lastTime;
    uint32_t timeRemain =  30000L - timeUsed;
    Serial.print(" Remain Time= ");
    Serial.print(timeRemain);
    uint32_t timeNow = micros();
    uint32_t timeCounter = micros();
    Serial.print(" Time Now= ");
    Serial.print(timeNow );
    Serial.print(" math = ");
    Serial.println(timeNow - lastTime );
     while (timeCounter < timeRemain ) {
   timeCounter = timeCounter + (timeNow = micros());
   Serial.println("Inside loop");
    timeCounter = 0;
    lastTime = currentTime;
    lineCounter++;
Use in what way?
Most people simply let the computer run, checking the clock, until it is time to do something. Study the Blink Without Delay tutorial to learn how that is accomplished.
I meant the process cannot continue until the 300 ms have passed. So intended to used that remaining time inside a loop to complete the 300 ms.
Thanks
while (millis() - last_loop_end <= 300UL); //do nothing
last_loop_end=millis();
} //end of loop function
