STP16DP05 ShiftOut Query
Hey everybody,
Okay, I've run into another problem with my new friend, the STP16DP05B1R 16-bit shift register.
I am following the ShiftOut tutorial, which tells me that for a sink driver such as the STP16DP05, I have to put the anodes of my LEDs to the common power line and connect the cathodes to the shift register outputs. I made sure to switch the line connecting the shift register board to the LED board from ground to positive. Everything seems to be plugged in properly. However, I am getting no response from the ShiftOut hello world.... :(
I have done a bit of sleuthing, and it would seem that the problem arises from the external resistor. I found a forum post here that says something to the effect of my problem:
http://www.picbasic.co.uk/forum/archive/index.php/t-7485.html
Not the same board but similar concept. What does it mean to "connect between VDD and the I/O"? I know what VDD is and where it is on my chip, but which I/O is this person talking about? Does this mean that I need to resist all of my LEDs individually?
Thanks in advance for your help everyone.
My head hurts.
the comment:
"They're called LED sink driver (kinda open-drain output on PICs)... so you must connect between VDD and the I/O."
Is, as far as i see it about the LED's not the current limiting resistor.
Can you meassure any voltage on the output pins ?
YES all LEDs must have there own resistor.
MikMo: I am reading a constant 4.33 V out of pin0 while running the ShiftOut Hello World. It would appear that power is running. It's the strangest thing though, I went back to following the original instructions in the tutorial (without the anodes and cathodes flipped) and I am getting a really faint light out of my LEDs. It does not blink, it just remains constant. Have any ideas?
Mike: Hey again, pal. I thought that the whole point of a constant current IC was the eliminate having to resist each LED individually. Am I wrong?
Here's an image of my setup. I hope it helps. I can provide a higer res version if needed.
Oh dear lord.... okay. Brain fart, everyone. Mixed up data and clock pins. I need to get new glasses......
Go about your business.
Mike and MikMo: You two rock. I'll upload the project when I'm done. See you on the boards.
I'm trying to get it to work on my end, and wanted to see the wiring.
